So I replaced the timing belt,water pump, thermostat,coolant temp switch,j plug about a week ago.All oem parts.Vacuum bled cooling system without issues.I replaced the heater core today.Still the same thing.I tried another climate control head performed basic settings no change.When driven at highway speeds under load vehicle has some hear but not a whole lot.There is no air in the system because I bled the heater core at the return hose with the hole in it.I am wondering if the radiator could be restricted??or partially blocked??Never had any issues.About 2 weeks ago the car would over heat in the morning when started and a key cycle would fix this.I found out that the coolant temp sensor on the rear of the head was no good and causing this so that was replaced.As mentioned just about everything was replaced beside radiator and lower temp switch on the lower radiator hose.Any chance this switch is my issue or the radiator is partially blocked???No faults stored in HVAC 08 or engine 01.Really weird.
