Results 1 to 13 of 13
    Established Member Two Rings nogaroblu's Avatar
    May 10 2015
    Chicago, IL
    Need help with Resetting either Immobolizer or the Cluster!
    I was messing with VCDS last night, I failed miserably.
    I failed because this morning as I was leaving for work I go to start the car and it starts, runs for a second and dies.
    How do I fix this, anyone know by the below what needs to be done? I really need this car back on the road, Please and Thank you in advance
    Thursday,21,January,2016,18:21:45:62939
    Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    Address 01: Engine Labels: 079-910-560-BBK.lbl
    Part No SW: 8E0 910 560 C HW: 8E0 907 560
    Component: 4.2L V8/5V G 0010
    Coding: 0007771
    Shop #: WSC 63351 000 00000
    VCID: 2541171FEF14DD36C75-5000
    4 Faults Found:
    17979 - Left Engine Mount Solenoid Valve (N144)
    P1571 - 001 - Short to Plus
    18107 - Powertrain Data Bus
    P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent
    18043 - Powertrain Data Bus
    P1635 - 008 - Missing Message from A/C Controller - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 008 -
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 8E0 910 156 HW: 09L 927 156
    Component: AG6 09L 4.2L5V USA 0020
    Revision: 00000001 Serial number: 0001945
    Coding: 0000002
    VCID: E3C5C90721A0E306691-50E6
    1 Fault Found:
    18275 - Powertrain Data Bus
    P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
    Freeze Frame:
    RPM: 0 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 30.0
    (no units): 95.0
    Temperature: 57.0°C
    T.B. Angle: 0.0°
    Voltage: 11.68 V
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 Q
    Component: ABS/ESP allrad 3033
    Coding: 04597
    Shop #: WSC 01234
    VCID: 3663C05312B2A6AE7EF-5000
    No fault code found.
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1219
    Coding: 00000
    Shop #: WSC 63351
    VCID: 63C54907F1A06306E91-5000
    2 Faults Found:
    01206 - Signal for Duration of Ignition Off Time
    27-00 - Implausible Signal
    00474 - Control Module for Immobilizer
    49-00 - No Communications
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul USA 0517
    Coding: 01013
    Shop #: WSC 63351
    VCID: 3561C75F0FB4ADB6775-4A9C
    4 Faults Found:
    01497 - Bulb for Blinkers; Front Right (M7)
    57-00 - Electric Circuit Failure
    01317 - Control Module in Instrument Cluster (J285)
    49-10 - No Communications - Intermittent
    79-10 - Please Check Fault Codes - Intermittent
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 C
    Component: Airbag 8.4EP 3001
    Coding: 0010607
    VCID: 377DCD5745B85FA6659-5000
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 04041
    Shop #: WSC 63351
    VCID: 3E73D8733A826EEEA6F-4A9C
    3 Faults Found:
    01303 - Telephone Transceiver (R36)
    01301 - Control Module for Voice Recognition (J507)
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 980 M
    Component: KOMBI+WEGFAHRS. RB4 D37
    Coding: 03200
    Shop #: WSC 02610
    WAUPL68E24A079130 AUZ6Z0C0196201
    1 Fault Found:
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1411
    Coding: 11788
    Shop #: WSC 63351
    VCID: 72EB3C433E5AFA8E927-4A9C
    Subsystem 1 - Part No: 8E1959801
    Component: Tőrsteuer.FS BRM 0003
    Subsystem 2 - Part No: 8E1959802E
    Component: Tőrsteuer.BF BRM 0003
    Subsystem 3 - Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0003
    Subsystem 4 - Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0003
    9 Faults Found:
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01561 - Rear Left Door
    59-00 - Can't Unlock
    01562 - Rear Right Door
    59-10 - Can't Unlock - Intermittent
    00938 - Switch for Electric Window; Rear Right (E54)
    27-10 - Implausible Signal - Intermittent
    01334 - Door Control Module; Rear Right (J389)
    80-10 - Single-Wire Operation - Intermittent
    End ---------------------------------------------------------------------
    Nov 12 2015
    Oregon
    what exactly did you "mess with" in VCDS?
    My build log
    May 10 2015
    Chicago, IL
    I just got the VCDS, so I was browsing around in it, trying to get used to it. I was in the instruments section when my laptop battery died, I unplugged everything, locked the car, went to sleep. Then in the morning when I was trying to leave for work it started, but shut off a second later...
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    do you have second set of keys ?
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Feb 13 2004
    AW E30 M3 & PB B7 RS4 (DD)
    If it is Immobilizer then you would not have any power IIRC
    Oct 02 2006
    Wadsworth,OH
    Clear this code then try and restart
    Jason
    May 10 2015
    Chicago, IL
    Quote Originally Posted by Lucca M View Post
    yes, already tried, does the same thing..
    May 10 2015
    Chicago, IL
    Jason
    Jason, you think that would be safe to do? I was going to last night but was unsure if I should or not
    Jan 17 2014
    New Jersey
    Quote Originally Posted by nogaroblu View Post
    Yes just clean that code
    Insta: luccamentone
    Oct 02 2006
    Wadsworth,OH
    Yep.
    Some how my car lost connectivity with my key and triggered the immobilizer. It would start for half a second or so and shut off just like you described. Hooked up my Foxwell tool to scan the engine codes and the first one I saw was the immobilizer code. Cleared it and it started right back up.
    You will literally not be able to start the vehicle with that code on.
    Jason
    May 10 2015
    Chicago, IL
    Yep.
    Jason
    Jason, I will try once I get home.
    May 10 2015
    Chicago, IL
    UPDATE
    So I ended up towing it to a shop that only works on German cars. I was told it would take a couple day, took a week but shes back on the road. The tech said he had to reprogram the IMMO, Keys, Cluster, and one other thing I cannot recall at the moment. Also said something about it now has the latest software installed that he had to pull from Germany?
    Regardless, after a week and coughing up $400 and driving my friends C230 K Sport, the S4 feels like a monster almost feels like its never ran better before, could it be the updated software or is it just me lol
    Jan 17 2014
    New Jersey
    UPDATE
    Did he just install windows 10 on your audi's computer? sounds fishy, he probably just cleaned up errors and maybe ended up recoding the immo. But i want that new software too!!
    Hey but the important thing is, car is back up and running! Enjoy it!
    Insta: luccamentone
