Results 1 to 9 of 9
    Established Member Two Rings nitronutz's Avatar
    Jan 20 2016
    louisville
    Any idea what this is?
    Hello, while checking for an oil leak I heard this valve clicking. The ambient air temp here is probably 20f. Is it normal? Can anyone id this part(The one with the electrical connection on the left)
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    That's normal. It's the N80/EVAP purge valve. It's suppose to click.
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Purge valve solenoid.
    Allows fumes from the fuel tank/charcoal canister to be pulled into the engine for combustion.
    Clicking is normal.
    Jun 08 2008
    Calgary AB Canada
    Looks like you may want to replace that check valve though
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Jan 20 2016
    louisville
    @onceover...do u have a part number for the check valve? And what are the symptoms for check valve failure?
    Sep 17 2014
    Lakeway
    Quote Originally Posted by nitronutz View Post
    Dude your evap/purge valve is fine. Swap it if you get the code for it.
    Jan 20 2016
    louisville
    I was referring to the check valve beside it, the previous poster had mentioned it might require replacement.
    Sep 17 2014
    Lakeway
    Well it might not need to be replaced if you aren't throwing any wrong flow codes but it assuming your car has over 100K on it it doesn't hurt.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    058905291K Yours appears to be corroded.
