Results 1 to 7 of 7
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    Is it a bad idea to ask for my old/broken parts back from mechanic?
    About to go pick up my car from my mechanic where I had the axle replaced. Since OEM axles are expensive and can be rebuilt, is it weird to ask for the used axle back? I'm assuming the mechanic takes these parts and rebuilds them and sells or uses them, if it's my part why can't I do that?
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    It's supposed to be your right to ask for your old parts.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    They are YOUR parts that came off YOUR car. Perfectly acceptable.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by lyates1987 View Post
    Absolutely.
    Jun 30 2008
    Erie, Pennsylvania
    It depends.
    In the case that he repaired your car using a "rebuilt" axle - either from Audi or from an aftermarket supplier, then part of the deal is to return the bad "core" axle to the vendor. The rebuilder needs the old ones back to keep their awesome axle-rebuilding-business going. In that case, there will be a certain cost associated with keeping the old one, and not returning it as a core. That cost would be the "core fee". The penalty charge for not returning the core. For an axle this is usually around $0-$40. The price varies and depends on supply, demand, failure rate, the cost of new ones, and other factors.
    In the case that a core fee applies to your replacement axle, AND you so choose to cover that fee yourself, then you can certainly have the old one back. It is, after all, your axle to begin with. Generally speaking, people don't ask for their junk parts back, so the mechanic will assume that you'd rather turn in the axle as a core instead of paying the penalty charge. He wouldn't even bother asking you.
    BUT, if he fixed your car with a NEW axle, and no core charge applies - then he is obligated to return the old part to you if you want it. Unless, of course there was some prior agreement where he keeps all your junk.
    That said, yes, I think you are smart to keep your OEM axle. Should your axle troubles turn into a revolving door of crappy, chinese replacement axles - you could either rebuild the OEM axle yourself, or send it in as a core to a high end axle builder like Raxles (who only take OEM axles as cores). Keeping the part is probably free, and leaves your options open. Now if the axle was clicking, it at least needs a joint. And if the core fee is $35, I might consider letting it go. You can get another junkyard OEM axle in good condition for that price.
    All of that aside, some customers ALWAYS ask for their old parts back, regardless of their condition. This is their way of ensuring said parts actually got changed with new ones. And sometimes to satisfy their curiosity of how badly the parts were broken. It is usually best to ask before the work is done, as things will often get thrown away pretty quickly. Some people just want to see the parts, and then don't take them. But coming from the mechanic's perspective (note: I'm not a mechanic...sort of), it is not at all unreasonable for someone to ask about their old parts. Either to see them or take them home. In fact, most would probably be proud to show how bad the damage was, or how and why the part failed.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    I make a point of rebuilding factory axles over buying aftermarket "new" units. I know there are good aftermarket parts out there, I just have control issues.
    Dec 28 2006
    Western Maryland
    Raxles is the way to go for me. Cost a little more but getting a rebuilt OEM from a highly reputable vendor is worth a lot for peace of mind. Put it in, no fuss no muss. My time and effort is worth way more than doing the rebuild myself or any potential savings by going with a cheaper replacement that may or may not perform the same as an OEM axle.
