Results 1 to 3 of 3
    Apr 10 2012
    2003 Audi A4 1.8T Quattro
    Fort Worth,TX
    Weird brake light switch issue ABS/ESP lights on
    Ok so this is odd, I got the ESP/ABS light coming on. Swapped the brake light switch. Still had a problem. So went for the brake pressure sensor (G201) Got that in today, installed lights went away for a bit. While driving they came back on and then went off. I wiggled the wires to the switch and the lights came back on. VCDS was still reading correct BAR pressure for brakes. Also Cruise Control wont turn off when I hit the brakes. Get home and mess with the switch, I have 2 now. And now the lights stay on solid and VCDS reads brake pressure at 249BAR which I know is not correct. WTF is going on here?
    Also my brake lights are working fine.
    2003 A4 1.8T Quattro Auto, Custom Stage1 tune, N70, 550cc Fuel Injectors, B7 console (with cup holders!)
    Apr 10 2012
    Fort Worth,TX
    getting this error in VCDS
    48-00 Supply Voltage
    Apr 10 2012
    Fort Worth,TX
    got the cruise control working by tweaking the brake switch. But still getting the above error, is it time to send the ABS module off?
