Ok i started this thread to ask for opinions on my engine. I was under the car doing a visual inspection on the exhaust. I am going to be gutting my pre cats (piggies) and before i get to it, i wanted to address what sounded like an exhaust leak. Upon inspection of the bottom of the engine/transmission, I noticed that the bottom of the Heads are EXTREMELY clean. The engine had a slight valve cover leak when i bought the car(along with a massive oil leak from the valley pan and the oil filter to block housing), and while doing the valve covers, i noticed that one(possibly both) of the gaskets had been previously done. So there is some dirt, oil and what not covering various engine parts. I will be cleaning the engine when i have some time. With all the old grime and stuff on the engine, the heads are sure clean for a 10 year old, 100k mile car. I then noticed that the sub frame bolts have been taken out before...along with the timing chain cover bolts. It looks like the gasket is newer and the bolts seem to have been touched at some point. (When i had the valve covers off, the chains were discolored and did not appear to be new) I bought the car with pretty much zero history except for it having the rear bumper and one of the mufflers being changed in the past due to a fender bender. Very few things show up on the car fax other then having the electrical system checked many times(has new alternator as of 2013). I recorded a video while laying on the ground under the car. It is horrible quality and its dark so its hard to see what i'm trying to point out, but can someone take a look and tell me if the bottom of the heads stand out as being pretty clean. I'm hoping that the timing service has been done and that the heads are newer(so i don't have to spend the money on timing components). I'm getting ready to order the timing components as preventative maintenance along with some other stuff, but if it has been done, i don't want to just throw the money away... I will try to record a better video soon. Its just odd how clean the heads are...opinions??
https://youtu.be/yQkKEG_cMns
