    Oct 27 2015
    Sarasota, FL
    Disable Amber Lights when Low Beams are ON - RS5
    Hoping someone can help me out here. I recently got ecodes and successfully got rid of the amber corner lights. However, when the low beams are on there is a different amber light that comes on. Any idea how to turn that off? It bothers the hell out of me!
    [IMG][/IMG]
    Thanks in advance for the help!!
    Oct 27 2009
    Miami, FL | Boone, NC
    Check if either of these bits are set to 1
    Front Turn Signals as Parking lights **
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 10 Bit 0 - Change 0 to 1
    Once the change has been made you can enable the front turn signals as DRL's by making the following change
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 2 Bit 6 - Change 0 to 1
    From: http://www.audienthusiasts.com/VagComEXLight.html
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Oct 27 2015
    Sarasota, FL
    Just double checked that. Does not seem to be the issue.
    Oct 27 2015
    Sarasota, FL
    Nevermind.. that was exactly the issue. Thanks Puter!
    Oct 27 2009
    Quote Originally Posted by bcloud89 View Post
    Glad it worked! The ecodes look great!
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
