Results 1 to 21 of 21
    Aug 06 2012
    Parker, CO
    Have A Noise - Need Help
    2013 allroad - 70k miles
    Between 40-50mph and noticeable, but light, thump-thump-thump sound that appears to be coming from the right front side. Can also feel it in the gas pedal
    Thump goes away faster than 50mph.
    From 70-85mph a noticeable hum. It got much louder after a tire rotation. Went back to the tire shop, they re-did the balancing, but noises still there.
    So, is this a wheel bearing or something else.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    How's your alignment?
    Did the noise move with the rotation?
    Do you have any vertical play in the wheels if the car is off the ground?
    EDIT: What do your tires look/feel like? Actually feel them.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Aug 06 2012
    Parker, CO
    It's certainly gotten louder since then
    No
    6/32 of tread left. Tires are in great condition.
    Established Member Two Rings ChornsYYC's Avatar
    Jan 30 2013
    Houston, TX
    If your tires are wearing evenly and the hum is independent of RPM and changes pitch with speed it's likely a bad wheel bearing.
    Aug 06 2012
    Parker, CO
    Quote Originally Posted by ChornsYYC View Post
    Tires are wearing evenly.
    Hum is only from 70-80mph, but does not change pitch.
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    40-50 is a thump thump kind of like a prop plane? Does it get louder when you are going around a corner in either direction?
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Aug 06 2012
    Parker, CO
    Quote Originally Posted by blbroo View Post
    No. It quiets down on hard acceleration, but more noticeable coasting downhill in that speed range.
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by treginginco View Post
    Can you tell what corner of the car it's coming from? Even if it's in the front or back? If so, move tires around one at a time to see if you might have a weird wear issue. Could be feathering or cupping.
    Aug 06 2012
    Parker, CO
    Coming from the right front. Did the tire shuffle yesterday. No tire cupping.
    Oct 26 2012
    St. Louis, MO
    I remember my wheel bearing being more noticeable coasting downhill too. When I think of the sound, the place I remember is a downhill near my house.
    Hear any grinding or have wiggle on that wheel when it's in the air?
    Aug 06 2012
    Parker, CO
    No grinding at all
    - - - Updated - - -
    No wheel wiggle
    Oct 26 2012
    St. Louis, MO
    All of your lower body pans / covers are on and secure? Just remembered that mine came loose once and gave me weird noises.
    Aug 06 2012
    Parker, CO
    Funny you should mention that as I recently had that big plastic/felt cover replaced.
    Oct 26 2012
    St. Louis, MO
    I bet it's flapping. Either it's loose, or the one you have now has enough slack in it to start slapping around.
    This could be the second issue I've helped solve with loose belly pans.
    http://www.audizine.com/forum/showth...-Cooker-Noise-!
    Veteran Member Three Rings mannyjfk's Avatar
    Dec 17 2010
    Mercedes Benz C Class
    Jersey City NJ
    Try rotating the tires to see if the noise goes where the front left tire goes.
    Aug 06 2012
    Parker, CO
    Great tip --- will get it checked out.
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Established Member Two Rings tekmo's Avatar
    Dec 08 2011
    I just had this and it was a front left wheel bearing on A3.
    Aug 06 2012
    Parker, CO
    Quote Originally Posted by tekmo View Post
    Fortunately.... I just talked to my Audi/VW guy (Hardey's Motorwerks) and if it is a wheel bearing ---- it's not that expensive.
    Aug 06 2012
    Parker, CO
    The AR is heading in to see Dr. Hardey next week ---- looks like it might be the right wheel bearing.
    Veteran Member Three Rings BrewDude's Avatar
    Mar 13 2009
    04 R32 FT450
    KLAS
    I thought I had a wheel bearing going on my BBS CH-R setup. Turns out it was the tires (Continental Extreme Contact DW's). Apparently I didn't notice the load rating when I purchased and more than likely did them in with the extra 200+ lbs the tires were not rated for vs. the car's weight. Put the stock tires/rims back on to confirm my theory, no noise at all.
    Replaced the Conti's with the latest version of Continental Extreme Contact DWS 06's, so far so good. At least these are the correct load rating.
    Aug 06 2012
    Parker, CO
    It's official --- there is no mechanical issue with my AR. My Audi guy checked the entire front end --- axles, bearings, CV joints, transmission, AWD system is all in great shape. Belly pans good and tight.
    Now.... will talk with my tire guys as that is the only thing left.
