Results 1 to 39 of 39
    Established Member Two Rings nitronutz's Avatar
    Jan 20 2016
    louisville
    oil smell please advise.
    Gmornin from ky,
    I've been experiencing oil smell inside the cabin. After some searching I've cocluded it could be a few things, pcv valve or associated tubing, valve cover gasket or cam tensioner seal, am I correct? Any thoughts?
    Also how can I tell if any those aforementioned parts are bad? Valve cover is obvious but I've read to diagnose the pcv by removing the oil cap, if it had a strong vacuum then pcv is bad? Also I do not know where to look for cam tensioner leak. Any thoughts are greatly appreciated.
    02 a4 1.8 5 mt.
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Oil smell inside the cabin I'd look for a leak in the pcv system or oil leaking. The cam chain tensioner seal is at the rear of the cylinder head nearest the bulkhead. Start looking for oil seepage around/under there.
    Esp look for the half moon gasket under the cam chain tensioner assembly. Very hard to see, will need the use of a mirror to even get a glance. Look under your intake manifold for a crumbling/cracking/failing pcv system as well.
    There is tons of documentation by the guys in this forum in a thread called "Engine Strengthening"... pretty sure that's the name of the thread.
    To check if some of the components are bad like you said about the vacuum, is a good idea. Checking the tubing I used a smoke machine, I'm sure there are a ton of other ways. Try a boost leak test, that should be able to locate a leak in the pcv tubing as well.
    Jan 20 2016
    louisville
    Thanks a bunch. I've been researching cam tensioner seal replacement as I seen lots seepage back there, can someone point me to a good diy?
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Check your valve cover too for possible leaking on the exhaust manifold
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by lyates1987 View Post
    Definitely check this first. Because of the extreme temperature differential above the turbo this side of the valve cover gasket is prone to leakage. That's where my burning oil smell was coming from. All it takes is one drop of oil on the exhaust manifold and the smell is pretty strong.
    Jan 20 2016
    louisville
    Can someone explain this,
    I read in the diy on cam tensioner seals where you have to put that back cylinder to TDC? Exactly how do u do that? I seen the timing mark on the block and I guess there's one on the cam or chain? The diy's photo is real ambiguous. So do I just turn the crank bolt till the two marks match? If anyone has done this please explain this part of the job to me. Thx
    Jan 20 2016
    louisville
    On a side note, I had a1990 G60.Corrado, I thought that thing was a PITA to work on...My b6 a4 put it to shame. Lol.
    Aug 20 2012
    Mesa, Az
    Quote Originally Posted by nitronutz View Post
    Put the #1 cylinder, closest to the timing belt, to TDC by lining up the mark on the harmonic balancer with the notch in the lower timing belt cover. Once the upper t-belt cover comes off check the cam gear, it should be at almost the 12 o'clock position. If not you're 180 degrees out so roll it over once more, there will be a mark on the valve cover to line up with the cam gear.
    Be sure there are 16 rollers in between the index marks on the cams, nearest the cam chain tensioner, these marks will also be at the 12 o'clock position once you're at #1 TDC and the valve cover is off obviously.
    The latter is the most difficult part of the entire process.
    If you don't own a Bentley manual I highly suggest one. I got a few from eBay, used for less than half brand new.
    Jan 20 2016
    louisville
    What's the significance in putting #1cylinder to TDC when changing the CTG? Some say you can change it without that step, cam someone confirm that?
    Aug 20 2012
    Mesa, Az
    You certainly can omit that step as it only provides a point of reference.
    Jan 20 2016
    louisville
    So it doesn't provide any more clearance for the CTG if I put it in TDC? Can I just mark the chain and sprocket and be done with it?
    Apr 10 2012
    2003 Audi A4 1.8T Quattro
    Fort Worth,TX
    do you have VCDS to check for codes? Sometimes an vac leak wont trigger a CEL but might show up in the logs.
    2003 A4 1.8T Quattro Auto, Custom Stage1 tune, N70, 550cc Fuel Injectors, B7 console (with cup holders!)
    Aug 20 2012
    Mesa, Az
    Quote Originally Posted by daverdfw View Post
    Good point, using the STFT, LTFT and O2 values can get you to the right area to inspect.
    Aug 20 2012
    Mesa, Az
    Well not that I'm aware of at least... as far as the clearance goes.
    As long as you mark or lock the timing belt to the exhaust cam sprocket using some binder clips or something and get your roller count dead on you should have no issues. I only pulled my intake cam out when I did mine and left the exhaust cam in entirely, there was barely enough room. Quite a bit of Jenga-ish maneuvers and lots of finesse.
    Jan 20 2016
    louisville
    Thanks man. Will be attempting the job soon. Tired of smelling the oil fumes in the cabin. Got like a spank load of snow in Ky. Hoping for a thaw out soon.
    Jan 20 2016
    louisville
    Guys I think I at least found one source of my oil smell. My T piece of my PCV system (#5) has a huge crack in it. Any advise on how to replace it easily? I know I eventually will need replace the whole thing but it's damn cold here and I haven't a home garage. I've read you might have to pull the TB , overflow tank. Any advise for this A4 Rookie would be appreciated. Oh yeah my #9 breather tube is metal, I guess some of them is plastic? Or is it aftermarket.
    BTW ThatOneGuy, love the avatar. Grew up playing streetfighter. I still bust it out on occasion on my genesis lol.
    Dec 28 2006
    Western Maryland
    If your tube is metal you either have an '02 or '03. Which one is it? At a minimum you will want to replace these components:
    For an '02 or early '03: Clicky click®
    For a late '03: Clicky click®
    It can be done by moving the coolant reservoir to the side and leaving the intake manifold in place. However, it will be pretty tedious working in the confined space. Removing the intake manifold requires a little more work but with a lot more room to access the components.
    Jan 20 2016
    louisville
    I have an 02 old guy. Is there a diy to intake manifold removal? Will it require new gaskets as well,?
    Jan 20 2016
    louisville
    Just found a diy. Draining coolants and pulling injectors? No thanks. Has anyone successfully changed all the pcv tubing without pulling the intake manifold?
    Dec 28 2006
    Western Maryland
    Yep. I did it about a year ago without pulling the intake manifold or draining any coolant.
    Jan 20 2016
    louisville
    Any surprises? Other then being a tight space to work in...all u did was remove the TB and move the overflow tank? Any tips would be appreciated.
    Dec 28 2006
    Western Maryland
    I didn't remove the TB. I just moved the coolant reservoir out of the way. Disconnected the "T" supply to the Evap line. Used a small hose duct taped to my shop vac to remove the crumbly pieces that will occur when you remove the "L" connection from the block. If you purchase the kit I linked you will have all the components you need.
    Jan 20 2016
    louisville
    Thank u kind sir. I think I might remove the TB and gain a bit more room. Worth it?
    Veteran Member Three Rings 1/4 scale's Avatar
    Mar 03 2004
    North Carolina
    Check the plastic elbow (#2) coming from the crankcase as well. Just replaced mine since it was brittle and cracked. Be careful not to drop pieces into the crankcase. Piece #5 has a small valve (#6) attached to it that you'll want to replace if you have high miles. I also changed the suction jet valve (not shown on the image) that connects the other side of hose (#10). You can do it without removing the TB. The hardest part of the job is taking off the clamps.
    2002 A4 Avant 1.8T • APR +1 • DSMIC • JJ tip • RS4 mounts • SB OFE HD • Apikol snub • B5 S4 binders • 18" Ultraleggeras w/ Conti D/Ws • APR exhaust • APR TBHose • Stasis SS • S4 rear sway • AMS ss • e-codes • Pzwo lip • S4 blades • USP roof spoiler • Apex track studs
    Jan 20 2016
    louisville
    I had planned out removing the whole thing as an unit then replace as one, you think it'd be enough room without removing the TB?
    Mar 03 2004
    North Carolina
    Yes, you can do it that way. As OG points out, careful of falling pieces into crankcase. Removing #2 can be tricky, it will probably break at the neck leaving the integrated metal sleeve. You might have to pry it out separately.
    Jan 20 2016
    louisville
    Cool thanks, as ur name implies do u fly rc aircrafts? It's one of my passions in life. Hope for spring to come fast!
    Mar 03 2004
    North Carolina
    architect
    Apr 10 2012
    Fort Worth,TX
    Quote Originally Posted by 1/4 scale View Post
    +1 on this, mine was broken as well when I bought the car. smelt oil all the time. Mine broke at the bottom. inspect it closely.
    Jan 20 2016
    louisville
    architect
    Awesome!
    Jan 20 2016
    louisville
    Please help. While trying to replace the dreaded plastic elbow today i found the metal ring and part of the pipe is stuck in the oil filter housing! How did u guys get it out? I didnt take the manifold off. Struggled for hours to no avail. I m think getting some extra long picks or a pilot bearing puller to do the job...advices??
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    I think this happens to a lot of us. I had to use a slide hammer to get mine out. It was stuck good. I then used a shop vac with a smaller hose attachment to suck as much of the debris out as possible. Good luck.
    Dec 28 2006
    Western Maryland
    Mine did the same thing. I just used a pair of angled needle nose pliers and went from one edge to the other and eventually worked it out. After I got it out I duct taped a long section of small diameter flexible hose to the the end of my Shop-Vac and sucked out all of the little chunks of plastic.
    Jan 20 2016
    louisville
    Note to self...google slide hammer.
    Can i use that method without removing the manifold??
    Aug 24 2014
    Vermont
    Try old guys method first. I had a slide hammer on hand so I went that route. Here it is if you were wondering. I did it with the manifold still on.
    http://www.harborfreight.com/automot...-pc-60554.html
    Mar 03 2004
    North Carolina
    It doesn't take a lot of force. I loosened it up by carefully prying the sleeve inward with long screwdriver (above the intake mani). Then I made a pick/hook from a long steel rod (coat hanger) and pulled up around the bottom of the broken tip of the pipe. It slid out in pieces. You'll get it, be patient.
    Jan 20 2016
    louisville
    Anyone have any opinion on my rear tracking arm blind nut? If the weld breaks can i just use a new press in nut and crank it down instead of dropping sub frame and weld?
    Jan 20 2016
    louisville
    I here by declare victory on the stupid oil filter elbow. Slide hammer worked like a charm. Wish me luck on my rear tracking arm tomorrow. Praying tge blind nut weld doesnt break!
    Jan 20 2016
    louisville
    No love from the blind nut. Weld broke as warned. Gonna drop the sub frame an inch and finish that bolt off with an air cut off wheel. Wish me luck.
