Results 1 to 13 of 13
    Jan 18 2016
    Olympia, WA
    Car Not Backing Up???
    Hey there,
    Had a quick question for you more experience Audi peeps. My newer 2014 Audi A4 appears it may have an issue with getting into gear. The car has around 23K miles on it. On cold mornings aka 24-32 degrees I always try to warm my car up before I drive away but I sit in the car for 15-20 mins and sometimes it will back up and sometimes it won't. The other day I waited 20+ mins and had to leave my house so I finally put in reverse and have to rev it a little and it jerked and then finally I could back up. I am wonder what might be causing this, if it is a normal thing due to complex transmission, a safety feature so you don't ruin your tranny from driving it so quick after jumping in, or if there might be something wrong going on here. As I posted on other posts I am a new Audi owner and am in need of some help.
    Comments are welcomed please!
    Thank you,
    -Alex
    Feb 24 2013
    CA
    Do you still have warranty on it? If so, fuck it up by doing what you're doing even more and take it in. Otherwise, I wouldnt even drive it. And no, it isnt normal. At all
    Jan 18 2016
    Olympia, WA
    Quote Originally Posted by Slick_B8 View Post
    I only did the rev 1 time. I mean I waited 20 mins and I had to leave for work -.- Car is still under double warranty. I guess I better just take it in. =[ sad to see it is messed up.
    Oct 10 2012
    Zionsville and Saint John IN
    Shit, you wait 20 mins? I just wait until the Rpms go to 800-900. Then baby it until the coolant temps reach a qrt.
    And yes take it in. That is not normal at all. Do follow up with us though after the dealer fixes it.
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Dec 12 2014
    Bolingbrook/Illinois
    That is definitely not normal, bring it in. Your warranty should cover it.
    2012 A4 P+ quattro S-line appearance
    Veteran Member Three Rings mannyjfk's Avatar
    Dec 17 2010
    Mercedes Benz C Class
    Jersey City NJ
    Not normal with newer or older models.
    - - - Updated - - -
    Quote Originally Posted by COLD13 View Post
    +1 ASAP
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Quote Originally Posted by mannyjfk View Post
    But rumored to be a standard feature on future models.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    Quote Originally Posted by dscline View Post
    Hilarious.
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
    Dec 30 2014
    Vacationland
    I once had a B5 Passat with a similar problem in its ZF tranny. Probably a stuck valve body or seal. Two choices, warranty service or sell.
    Feb 23 2015
    2014 Audi A4
    Fort Lauderdale, Florida
    Hmm, I always thought this was normal. I don't let my car sit and idle to warm up. When I put into reverse I always have to tap the accelerator to get it going, If i only release the brake pedal it won't move or hardly moves. And before you ask no the parking brake is not engaged.
    Senior Member Three Rings Slim0531's Avatar
    Aug 05 2014
    2010 Santorini Black Land Rover LR4
    Does this happen only on startup in the morning? Do you see any oil stain under your car? If you do not have any codes, the service technichian will ask you to replicate the problem for them to acknowledge that indeed there is something wrong with the car. I am pretty sure you still have warranty on that car unless your already TD1. Also, you do not have to wait for up to 20 minutes to warm up your car. The longer you idle your car in the cold, the more detremental it is to your engine. Read an article about this yeterday evening. As Good luck.
    Jun 23 2013
    PacNW
    Sorry to suggest this but, you're taking the electronic parking brake off first, right?
    What you describe sounds like what would happen if you had the EPB on and tried to start moving in drive, it dis-engages at a specific torque level. Not sure if that would apply in reverse though.
    Jun 26 2009
    Bremerton WA
    Are you parked on a steep slope. Auto trans has a hill hold feature as well. It can be a bit abrupt.
    VMR 710's, APR software, Eurocode HFC
