Results 1 to 19 of 19
    Junior Member Two Rings Glennb's Avatar
    Sep 27 2015
    2020 V6 Tacoma
    What is more reliable.
    domt start roasting me saying that you don't get an b5 s4 for reliability you get it for speed...I know I've heard it all before.
    So what is more reliable
    A stage 3 b5 s4 w/ 130000
    Or
    A dead stock b5 s4 w/ 130000
    And yes both cars have had timing belt, water pump and pulleys done.
    Jun 08 2014
    Vancouver, Washington
    Stage 3. Fresh turbos vs. 130k turbos. Everything has been refreshed if it's a well sorted stage 3.
    Sep 27 2015
    2020 V6 Tacoma
    Yes there are ko4s on the stage 3
    Thank you
    Jun 08 2014
    Quote Originally Posted by Glennb View Post
    Thank you
    Know how many miles are on them and if they've been driven hard etc?
    Sep 27 2015
    2020 V6 Tacoma
    I don't know how many miles are on the ko4 turbos but the dead stock one was never abused it was just a car used for commuting so that's why I don't really know which path to take. Honestly I've never had a fast car before. I'm only 18 so I feel like the stage 3 is a little out of my league
    Jun 08 2014
    Hmm that's a toss up. I'd definitely ask the guy with the K04's. If they are decently low I'd probably go for that one. Saves a good amount of money down the road if you were to buy a stocker and do stage 3.
    Being 18 doesn't really factor in as long as you can maintain it and afford the maintenance. I believe wagonholic is about the same age and drives a stage 3 avant. I'm 18 and mine is stage 2. If you can afford it, and know your way around cars a bit, go for it.
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Neither of them. They are both s4's.
    Established Member Two Rings KeatS4's Avatar
    Sep 14 2015
    B5 S4 white, B5 S4 Silver, 65 Impala, 66 Nova SS, Mk1 Rabbit, Mk2 GLI, Mk3 GLX, Mk4 VR6, 03 Mustang
    Long Island, NY | Denver, NC.
    I've said it before, I must have gotten the only 2 B5S4s that aren't garbage. Both of them are dailys, one at 130k and one at 160k. Maybe no one else cares for them? Maybe I just jinxed myself? Maybe they're A4s in disguise?? Only part I broke was a throtle body boot and like some other little thing. Everything else has been normal wear and preventative maintenance. Granted the 160k needs new struts within this year and I think a hub is going but not anytime soon
    Repair Cost Since 2006: $32,375
    Unitronic Stage 1+ @ 18psi, APR R1s, Stage 1 clutch, SACC 3"-2.5", Silicone hoses, DarIntake, Thule rack system, dope headliner
    Veteran Member Three Rings audi-hammer's Avatar
    Aug 28 2009
    Buffalo,NY
    What he said, I have two stage 3's, one at 70k miles and one at 165k. More reliable than all my friends performance cars so far
    Silvia = 02 s4 stageIII
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    they're the same. The k04's are supposed to be a better turbo, but turbos are inherently high wear items under hard use. I think driving habits and tune and how up to date maintenence is more significant. if you were to match the tune from a ko4 to ko3 power, i suspect it would be more reliable because the turbo is running lower rpms to produce the same power. But if you run more power, naturally more components will fail (boost hoses, clutch, tranny, diff, tires, brakes, overall heat buildup in all systems). So by that logic, a k04 car with more power is less reliable.
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    I had a period of time after my Stage 3 setup where I was dealing with issues daily.
    Now that all that's behind me, It hasn't been any different than before, just a hell of a lot faster.
    Purchased in October 2014, Stage 3 in August 2015, and daily driven throughout. Only big mechanical failure was the starter, which didn't strand me because it's not an Auto.
    Been reliable for me, but I spent the first 10 years of my working life honing my mechanical skill set. I would have burned it to the fucking ground if I didn't know my way around an engine.
    Veteran Member Three Rings e30mclow's Avatar
    Feb 08 2015
    An Irishman living in Canada
    According to Matt Farah - All 18yr olds that drive b5 S4s will crash them.
    I have a stage 3 k04, and would be apprehensive selling it to an 18yr old. Maybe I'm just getting grumpy with age.
    Current: 1998 Mitsubishi Pajero Evolution
    1990 BMW E30 with 1JZ
    Previous Bad Ideas: 2000 Black Stage III (BW-K04); 2000 Imola Stage III (BW-K04)
    Previous "Better" Ideas: Euro e30 m3, Euro e34 m5, Inca Orange 2002Tii, '89 325iS, '89 318i, '90 318iS, '91 318iS, 2 X '87 316, '89 320i, '81 316 and so on..
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    Id take the stock one. Prob get it for a lot cheaper and you can mod yourself properly. I bought a poorly modded stage 3 when i didnt know anything about the platform and i had to undo and fix everything the last retard did. And i mean EVERYTHING till it ran right..
    The brake booster hose was attached to the manifold via duct tape for example, didnt find out till i was trying to stop from 120mph with no brake booster...
    Shop wisely!
    Oct 26 2015
    South Dakota
    I'm only 17 and own a stage 3 b5 s4. I was really looking for a clean well taken care of stock b5 but none in my area met those specifications so i ended up getting a pretty well sorted stage 3 and it has yet to let me down reliability wise.
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by rguil View Post
    Shop wisely!
    This. I found all kinds of janky shit the previous owners of my car did to it and it's been so much preventative maintenance and preemptive replacement of many parts along with my own mods in preparation to go stage 3 this year. Either find a well documented well sorted out stage 3 from someone like a reputable forum member or find one that's stock or close to it and know you dis it right yourself
    It's amazing to think that my 299K mile B5 S4 with a fair amount of neglect and all kinds of little issues has yet to leave me stranded besides the green coolant temp sensor failing (had another on hand) and the brake booster firewall hose cracking. Otherwise, it's been dead reliable when on paper, it should be the very definition of circumstances to create the most unreliable B5 S4 of all time.
    2024 M3 Comp xDrive
    Jun 08 2014
    Ditto to many of these guys. It's been the most reliable out of all my friends' cars and it starts up with no issue every time :) Sometimes I'll smell something weird like fuel or oil coming through my vents and start freaking out but its gone in a couple minutes haha. No I don't have any leaks ;)
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    Quote Originally Posted by MarlinFoundNemo View Post
    yup, I'm 18 and drive a stage 3 avant. hasn't really been an issue for me for the most part since I do take care of it. YouTube/Google helps lol.
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Quote Originally Posted by christianb5s4 View Post
    Duuuude, near-300k? Your car is in such great shape, I'd have never put it much over 120k.
    Mar 01 2014
    Los Angeles, CA
    Quote Originally Posted by e30mclow View Post
    when we filmed the video, I was only 17 lol.
    I was only 16 when I got into stage 3. But over 2 years later, I'm still here.
    Justin
    #YEengineering
