Results 1 to 17 of 17
    Jan 20 2016
    Alberta Canada
    Unsolvable Two Litre Trouble
    So my wife has an 08 A4. Bought it around 2 years ago. Right now its sitting at arond 185000 Km (115 miles). Started having trouble with it about a year ago, when it was cold and you would get up to speed the RPM would kind of bounce up and down maybe 150 RPM. it stopped once the car warmed up so i never thought much of it. Then it started doing it at idle, RPM bounced 200 or so up and down. shook the car and sounded like it was going to die. Took it to a shop where they replaced the coil packs i believe. it might have fixed it for a few days but then it continued. Next they tried the pcv valve. still nothing. the Check Engine Light was on, and when i would clear it the idle would clean up for a while but start up again after a drive. I believe the next thing they told her was that the throttle body needed to be replaced. not wanting to spend the money we left it. i took the throttle body off cleaned it up and everything seemed fine with it. eventually she took it back to them, they said if the throttle body was not the problem they wouldnt charge for it. so she let them do it, and big surprise it fixed nothing, bigger surprise they would not refund her money. they removed the pcv valve and blocked it off, said it was a temporary fix. told her the engine harness needed to be replaced. she called the next day to get a quote to replace the harness (just for a laugh) and they told her they were not interested in working on her car anymore. so car sat for 4 months or so, now needing a vehicle to drive we were forced to start driving it again. the pcv valve is still blocked off so it idles fine but the other day on her way to work she told me the car would not go over 80 km/h said it would shift down and rev up but wouldnt go over that speed. on her way home it magically fixed its self. but has happened again once since. i have no idea what to do with this car. im sick of spending money on it, but it cant be sold in its current state. check engine light comes on sometimes goes off other sometimes. its currently off or i would write the codes down. anybody have any ideas?
    2008 A4 2.0T
    Feb 24 2004
    Minneapolis
    1. Your shop hasn't guessed right yet, stop going to that one.
    2. Find a shop that does Audi's, might even be the dealer. But someone who can VCDS that motor and see what's going on. Whatever it costs, it's less than the beating you'd take if you sold it this way.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    What do you mean they removed the pcv valve and blocked it off? Any pictures to show what is happening under the engine bay?
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    As mtroxel says, get the car scanned. If you can get it scanned with vag com and post the codes here people might be able to help with what's wrong. And definitely go to a new shop that specializes in vw/Audi.
    Jan 20 2016
    Alberta Canada
    Quote Originally Posted by mtroxel View Post
    The shop it was at was a Audi/VW specialist. The car throws about 6 codes all at once which is why they said they had to try to eliminate possibilities. What is the difference that they can see with a Vcds compared to was regular obd2 scanner? Thanks
    Jan 20 2016
    Alberta Canada
    Quote Originally Posted by Denio24 View Post
    I'm not sure if they removed it or just blocked it off. I'll grab a picture when I can. I really don't know these cars sorry if I'm a little slow. From what I remember they had a hose with a plug in the end underneath the plastic engine cover.
    Jun 27 2011
    And this is why I never trust shops with my car. They just play parts darts until they hit something that sorta kinda fixes it.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by whatyourbeef View Post
    You see pending codes (codes that are not triggering a check engine light), and can see/log data in real time. That would be invaluable for your issue. Less important to your issue, you can also adjust, or recode, modules.
    Whatever your shop is, I don't have faith in them. Replacing coil packs seems to be everyone's "go to" solution when they don't know what's going on. You would do that if you knew the problem was in the ignition system. And if they had good reason to believe the problem is in the ignition system, why would your next guess be to replace the PCV valve? Then they jump to the throttle body......I could go on and on. I don't think these guys have a plan. They're just throwing parts at it.
    Go to the dealer.
    Aug 04 2015
    Kansas City
    Torque converter issue? See this thread, scroll down a bit:
    http://www.audiforums.com/forum/b7-m...ulsing-178931/
    Feb 24 2004
    Minneapolis
    KJack, thought of that one too. I'd be interested to know if the surging idle goes away if you put it in Park.
    Jun 27 2011
    Having had the torque converter issue on my previous b7 this issue sounds different but I suppose that could be a possibility too.
    -CP
    2017 Q7 3.0t
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    get it scanned by an Audi shop. Engine Harness...lmfao
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    If I were you Id go down to the court and get the paperwork for a small claims suit (if they have that in Canada --or the equivalent)--fill it out and then slap it down and say ---you need to refund me the amount of $ you agreed to -or I'll file. You'll at the very least have to take time to show up to defend the suit--or by default I win and you will pay no matter what.
    That works sometimes to get people to honor what they claimed in the first place.
    If the truly feel you are wrong sometimes they're hard headed---but no one wants a summary judgment--so they'll at least have to show up---or theyre dunzo!
    Veteran Member Four Rings billyhoyle's Avatar
    Jul 29 2010
    2007 GSXR-600, 1977 GS750, mice
    Calgary, Alberta
    Where in Alberta are you? If you're in Calgary, Tunedub is the place to go for VW/Audi work.
    2005 B7 A4 2.0T | Brilliant Red | 6MT
    Jun 30 2009
    Washington DC
    OBD2 scanners spits out generic codes. VCDS codes are more specific and would lead the mechanic to the potential problems. A log of what could be wrong would also be a tale tale sign whats happening with the car.
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    There are reputable shops out there though that actually know what they are doing. We get customers coming to us all the time because the shop their car was has been changing parts and not just diagnosing the problem.
    We even get cars where other shops tell them they need a new engine and we find it was something simple like a spark plug. (true story)
    Nov 15 2011
    Montreal | I sell in USD
    Quote Originally Posted by 1killera4 View Post
    [hypothesis]Shop probably said throttle body harness since they mentionned replacing the TB and OP states engine harness by mistake. There's a tsb for the throttle body harness. Car is probably giving codes pointing in that direction.[/hypothesis]
    *****I sell in USD*****
