Results 1 to 7 of 7
Thread: Snub too high
    Oct 21 2005
    y
    Snub too high
    Has anyone have their snub mounts sit too high? Snub cup on engine is maxed to highest position and the snub is still resting on the cup.
    I cracked the aluminum bracket where the engine mount connects to chassis. That could've mis aligned the radiator thing where the snub mounts. Welded it while waiting for the replacement bracket. Both brackets had the snub in the same position (engine too high / radiator too low)
    Other than the snub cup on engine is there any more adjustment that can be done? Or just bend the radiator snub up (tried it without removing the snub, snub just got squished lol) could try using an open wrench to jack up the bracket.
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Try separating the subframe front from the plastic front end radiator mount (thingy name name???). I find that it aligns better when I separate the two to get the snub lined up.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Jan 21 2008
    Tucson
    Motors mounts are shot and the front of the motor is sitting a bit lower?
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    There is some vertical play in the front crossmember, which is the black piece that the snub sits on and the stock 1.8T uses to route charge air from turbo to SMIC. You can try adjusting this, but keep in mind if you do you may need to also play with the height adjustment on the bumper shocks.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Oct 21 2005
    y
    Quote Originally Posted by mysman View Post
    Engine is sitting too high
    Quote Originally Posted by MetalMan View Post
    How? Thru the bumper shock bolts? Cant remember any adjustment, been a while since i had the car in service position.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by ricekikr View Post
    Yeah, bumper shock bolts.
    Oct 21 2005
    y
    Thanks
