Results 1 to 15 of 15
    Veteran Member Three Rings strtdrms's Avatar
    Apr 03 2012
    Noblesville, IN
    Opinions on timing belt tensioners
    Replaced my timing belt and related components in March of 2015. I remeber checking the timing belt mid July and it was good. Before putting the car away for the winter I noticed a weird slapping sound coming from the area. Turns out my timing belt is really loose. I'm not sure if I didn't torque it properly or if it's getting ready to fail. I'm getting ready to buy a new tensioner to install come spring time. Wanted to know what I should go with. I bought the timing belt kit from blauparts. I think it was an Ana tensioner that came with the kit.
    2003 A4 1.8T Avant 5MTQ My Progress Thread
    2003 A4 1.8T Avant TIP - Daily Driver
    Instagram: mr_avant
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Did you purchase the kit with the newer version Litens belt tensioner and bracket or do you have the piston/plunger type tensioner and pulley?
    Apr 03 2012
    Noblesville, IN
    Newer litens belt tensioner.
    Instagram: mr_avant
    Jan 06 2009
    That tensioner is made in Canada so it can't be bad.
    Did you line up the tabs properly? what did you torque the bolt to?
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by strtdrms View Post
    Wow....Sorry to hear that. The Litens is what i was planning on using the next time I changed my timing belt/tensioner. It appears to be a much better arrangement than the piston/plunger type tensioner. I'm very interested to see what you find. Maybe it wasn't tightened up enough as ADCS questioned?
    Apr 03 2012
    Noblesville, IN
    That's what I'm thinking. I followed the instructions with the kit and rotated the crank several times but who knows. I'll be sure to double check this time around. Just still undecided on what to go with
    Instagram: mr_avant
    Aug 26 2005
    You probably don't need a new tensioner, since the installed tensioner is most likely only loose. Retightening should be all that is needed.
    Vorsprung durch Technik
    Apr 03 2012
    Noblesville, IN
    I've considered this but I don't want to go through all of the labor just to do it again if it was the tensioner
    Instagram: mr_avant
    Jun 30 2008
    Erie, Pennsylvania
    I'm pretty sure you can retension the Litens unit without doing hardly any disassembly. Just pop the top plastic cover off and you're there. I'm not sure if you can actually change the tensioner, but I'm pretty sure you can at least adjust it and retorque it.
    Aug 26 2005
    I recommend using the same Litens tensioner as is already installed, it is superior to the version used before.
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Is the old tensioner really that bad? I just picked up a kit with NTN tensioner. I don't want to touch it for at least 60k miles.
    Veteran Member Three Rings Toronto5.5's Avatar
    Apr 03 2011
    Nah plenty of folks have been using standard tensioners for years. This Litens tensioner is relatively new to the market.
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by eljay View Post
    The old tensioner seemed fine to me. Most people change it around 75K. I think the water pump is more prone to fail before the tensioner. My waterpump was crumbling when I last changed my belt. Maybe a combination of this new style tensioner, metal water pump and Kevlar belt can got twice as long? Who knows.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Aug 19 2013
    minnesota
    I"m using the NTN tensioner, I like that it takes up slack with the plunger. That nut that hold the tensioner or I think your case the pulley is a piece of crap, I replaced mine with a washer and grade 10.5 nut from menards and buttered the works with red loctite. The nut coming loose was responsible for taking out one of the our fellow 1.8 hipsters motor.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Are these Litens tensioners torqued to 23 Nm?
