Results 1 to 27 of 27
    Oct 28 2012
    Bloomington/Indiana/USA
    Door actuator part number??
    Hello,
    I have a 2009 Audi A4 B8 model that has problem with a door actuator on my driver's side door.
    When I try to lock my car with the key fob, it doesn't lock and the power lock light blinks for couple of times and then stays red. Of course, the door doesn't lock or unlock. However, when I use my physical key and open it manually, it works completely fine.
    My local Audi dealership told me I have to switch out the door actuator/latch and asked for $600. I'm assuming if I purchase the parts myself it would coast less. Did anyone have problem with this issue? anyone with part number or information on where to get an actuator?
    I am willing to buy one if there if someone is selling. Just shoot me a message.
    Your help will be much appreciated.
    Thank You
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    I've been seeing a lot of these lately with the older B8's. Seems like it's slowly becoming a common problem on the early models - maybe they have a greater failure rate after 5-6 years.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Apr 28 2014
    Philadelphia
    Same problem with my 2009
    Here are the p/n's:
    Up to the production date 11/02/2009 - 8J1837015B
    From the production date 11/02/2009 - 8J1837015F
    Watch out - the connectors are different on each one.
    vs.
    Registered User Four Rings Pelican Parts's Avatar
    Jun 08 2015
    B7 A4 Sline, B7 RS4, '04 STi
    Harbor City, CA
    Up to production 11/02/2009 HERE
    From production 11/02/2009 HERE
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    Quote Originally Posted by stseo6143 View Post
    Hello,
    Thank You
    Same thing happened to me on my 2010. I bought the part from a Porsche dealer for a fraction of the cost and installed it myself. Let me find the thread where I have the pictures of how to do it.
    Sent from my VS985 4G using Tapatalk
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
    Aug 10 2011
    North Whittier
    Here you go. All you need to know to do it yourself.
    http://www.audizine.com/forum/showthread.php?t=674777
    Oct 28 2012
    wow, thank you guys for so much help!! you guys are awesome!!
    나의 STV100-1 의 Tapatalk에서 보냄
    Aug 10 2011
    North Whittier
    I called the dealer and provided them with my VIN to get the correct part number.
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / B7 S4 Avant 6MT / Subaru Outback Limited
    Instead of creating a new thread, figured I could bump this one for some current info..
    Actuator on drivers' side is going out on my '09 A4 and the part number 8J1837015B appears to no longer be available through the AudiUSA website. Seems that it can be sourced though FCPEuro, Europa for around $200. But was curious if anyone found an updated part number that would be compatible? Per the above, 8J1837015F has a different connector. I was hoping to order through my local dealer (Audi Flatirons) as they typcially have 15-20% off MSRP. Thoughts anyone?
    Cheers,
    Ry-man
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Yes the updated part number is the new revision, you want the one thats from porsche because it is cheaper than the OEM audi part.
    Jul 16 2018
    Atlanta
    On the subject of the lock mechanism pinout change at Nov 11, 2009, from what I can find:
    >> lock unit
    - pre-Nov 11 '09
    front left (lhd) - 8J1 837 015 B
    front right (lhd) - 8J1 837 016 B
    rear left - 8K0 839 015 A
    rear right - 8K0 839 016 A
    - post-Nov 11 '09
    front left (lhd) - 8J1 837 015 D, replaced by 8J1 837 015 F starting Nov 3 '14
    front right (lhd) - 8J1 837 016 D, replaced by 8J1 837 016 F starting Nov 3 '14
    rear left - 8K0 839 015 D, replaced by 8K0 839 015 G starting Nov 3 '14
    rear right - 8K0 839 016 D, replaced by 8K0 839 016 G starting Nov 3 '14
    >> harness plug
    - pre-Nov 11 '09
    driver - 1J0 973 715, 10-pin
    passng - 1J0 973 714, 8-pin
    rear - 1J0 973 714, 8-pin
    - post-Nov 11 '09
    driver - 1J0 973 714, 8-pin
    rear - 4F0 973 706, 6-pin
    >> wiring
    F220, front driver's door central locking lock unit
    - pre-Nov 11 '09
    1 - brown/blue
    2 - gray/green
    3 - violet/yellow
    4 - gray/violet
    5 - blue
    6
    7
    8 - brown/red
    9
    10
    - post-Nov 11 '09
    1 - blue
    2
    3 - violet/yellow
    4 - brown/blue
    5 - brown/red
    6 - gray/green
    7 - gray/violet
    8
    F221, front passenger's door central locking lock unit
    F222, left rear door central locking lock unit
    F223, right rear door central locking lock unit
    - pre-Nov 11 '09
    1 - brown/blue
    2 - gray/green
    3 - violet/yellow
    4 - gray/violet
    5
    6 - brown/red
    7
    8
    - post-Nov 11 '09
    1
    2 - brown/blue
    3 - gray/green
    4 - violet/yellow
    5 - brown/red
    6 - gray/violet
    7
    8
    If there's further difference between the pre and post Nov 11 '09 lock units that prevent retrofitting a newer unit to an older car, I have no idea.
    If you need the driver's door pre Nov 11 '09 unit, it does seem that buying the Porsche part is more cost effective:
    https://www.eeuroparts.com/Parts/850...de-8J1837015B/
    or used even:
    https://wolfautoparts.com/catalogsea.../?q=8J1837015B
    As noted, if you do elect to try the replacement part, you'll need to buy the plug too and swap that out also.
    I find it interesting that Audi lists even the latest lock units as "no longer available", for all four doors.
    2009 A4 Avant 2.0T quattro Prestige, 270k miles
    Veteran Member Four Rings rcprato's Avatar
    Jan 30 2018
    21 Jeep Grand Cherokee Overland
    Rochester, NY
    Quote Originally Posted by Spawne32 View Post
    I bought mine from Sunset Porsche online, took me about a week to get and works perfect
    May 06 2015
    @Smac770 - very helpful info, thank you for posting. I’m probably the minor in this forum with an early model B8. I too question why the original and revision are no longer available from Audi. I have to pick up some parts from the dealership tomorrow for my S4 so I might inquire what the mechanics are doing when a B8 comes in with this problem.
    I’ll scope the Porsche dealerships as I don’t want to by a used part given the failure rate.
    Cheers,
    Ry-man
    Established Member Two Rings Ejr's Avatar
    Mar 24 2021
    Duluth, GA
    Quote Originally Posted by Smac770 View Post
    >> lock unit
    - pre-Nov 11 '09
    - post-Nov 11 '09
    >> harness plug
    - pre-Nov 11 '09
    - post-Nov 11 '09
    >> wiring
    - pre-Nov 11 '09
    1 - brown/blue
    2 - gray/green
    3 - violet/yellow
    4 - gray/violet
    5 - blue
    6
    7
    8 - brown/red
    9
    10
    - post-Nov 11 '09
    1 - blue
    2
    3 - violet/yellow
    4 - brown/blue
    5 - brown/red
    6 - gray/green
    7 - gray/violet
    8
    - pre-Nov 11 '09
    1 - brown/blue
    2 - gray/green
    3 - violet/yellow
    4 - gray/violet
    5
    6 - brown/red
    7
    8
    - post-Nov 11 '09
    1
    2 - brown/blue
    3 - gray/green
    4 - violet/yellow
    5 - brown/red
    6 - gray/violet
    7
    8
    or used even:
    I changed the front pass. side on my 09 A4 Prestige and it had 7 pins which is not listed here on pre or post Nov. So I’m not sure what infor is correct, cause now the driver side is dying. I don’t wanna have to open it to find out. I also once changed the rear driver side (left) and it had 8 pins, so I’m guessing mine is Pre Nov, but for the pass front according to quoted, it would be wrong info.
    Jul 16 2018
    Atlanta
    Your build date is on a sticker at the bottom of the driver's door jamb. But any MY09 was built before May '09.
    https://i.ebayimg.com/images/g/-FMAA...px/s-l1600.jpg
    There might only be 7 physical pins installed, but it's still an 8 position plug interface.
    Mar 24 2021
    Duluth, GA
    Mine says AG 10 08. So I’m guessing August 10th 2008 or August 2010 8th lmao, I’m not what format they used. But it’s funny cuz my VIN ends with 09N031292 meaning 2009 Nov, and that’s the year of production far as I know.
    So this here would be considered a 10 pin interface?
    Jul 16 2018
    Atlanta
    VIN ...09N031292 means it's a 2009 (9), built in Neckarsulm (N), sequence number 31292 (031292)
    AG is German version of incorporated. Audi's formal name is Audi AG. The build date is Oct '08. I believe the actual day of month of the build is marked somewhere, but I forget where.
    Look at the plug side, it's a 10-pin plug. So yes, I would call that a 10-pin interface, 2x5.
    Notice in this J519, not all the pins are present on each of the 17-pin plugs. But it's still a 17-pin plug and I would document the signals from 1 to 17. Such as the lower left in those case always being pin 14, pin present or not. Because that's position 14 on the 17-pin plug. (I might have it backwards and it's 8, but it's 8 or 14, I forget which).
    https://i.ebayimg.com/images/g/~VYAA...ud/s-l1600.jpg
    Mar 24 2021
    Duluth, GA
    Wow I never knew that’s what the N stands for. I think that place would be at the bottom of the drivers door jam, it says 10 08 I guess like you said then, August 8th. So it’s a 10 pin putting but with 9 actual pins?
    Jul 16 2018
    Atlanta
    Oct '08. The 10 is clearly not the year when your car is a MY09. There's no reason to presume either of the two digits is a day of month until someone shows an example from MY09-MY12 with a digit larger than 12. On mine, it's 08/08, so of no help in that regard.
    I don't know how many pins are actually mounted on the device side for the driver's door lock actuator. Never looked at it. But it would appear so - https://www.aliexpress.com/item/33039550609.html But even with 9 pins present, there's still only 6 wires going to the 10 position plug.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    Both rear doors on mine will not unlock and occasionally lock. I have to reach in from the front door and do the double pull to get them open and lock them with the manual "hole" inside the door frame. It's irritating but for what the latches cost, I deal with it. When the front door latches crap out, I will have to replace them. I think there's a DIY fix for the small motor in the latch that fails but I'd have to dig around.
    To add insult to injury, the power door locks on my near 25 year old Nissan Pathfinder with 260,000 miles all work just fine.
    B6 S4, B8 A4, 8P A3, and something, something.
    Mar 24 2021
    Duluth, GA
    My bad, I meant to type October 8, I was drowsy. But yeah, I guess only way to know for sure would be to open it up. I will buy the one I sent a picture of in my previous post, and try to install it. So I’m thinking it’d be safe to assume my prod date was 10/08/09
    Mar 24 2021
    Duluth, GA
    Quote Originally Posted by RPMtech147 View Post
    Since I got the car with 150k mi over a year ago I’ve replaced both the front pass, and rear driv. I believe they were stock. Kinda a hustle but it’s a lot of DIYs on YouTube, you just gotta be careful not to brake any tabs. With the front pass I go one off of Amazon but it crapped out in like 2 months. I got another from eBay Dec 2020, and straight off the bat it had better quality even with how it latched to the door jam or whatever they call it. So after the rear driv had your symptoms too (died), I went and got the same brand in January, they both work superb so far. Unfortunately they don’t have any for the front driv. I even contacted them on eBay; responded saying they don’t have it, but as of right now their eBay store is empty so idk what’s up with them. If you feel like new OEM is expensive, best bet would be to get a used one but with that, there’s no telling when it will go out on you. It’s a bunch of brands out there & I’m not trn be their tester as I did with the Amazon one. So I’ll just take my chances with used OEM or OEM.
    https://www.ebay.com/itm/Rear-Left-D...-127632-2357-0
    Jul 16 2018
    Atlanta
    Quote Originally Posted by Ejr View Post
    You have a MY09; there's 0 chance it was built in Oct '09. MY10 production would have started in May '09. The 10 08 should be read as Oct 2008; as mentioned, I see no evidence of either digit being a day of month.
    Mar 24 2021
    Duluth, GA
    Gotcha. So what do you figure would be the prod date?
    Jul 16 2018
    Atlanta
    The warranty booklet explains the PR codes sticker documents month/year of manufacture, replicated on the door jamb. There is no record of day of month of manufacture on the car itself that I know. I only have an idea of my day of month because the original battery adaptation in the J533 history data is Aug 14, 2008, at 1:51pm. My stamped manufacture date being 08/08, ie Aug 2008.
    I don't know of anything that was changed during Oct '08, so there's not really any value to a day of month for your build anyway. Start of Nov '08 had changes mid-MY09; Nov '09 had more substantial changes mid-MY10. Neither of which apply to your Oct '08 build.
    Mar 24 2021
    Duluth, GA
    I’ll try look for this PR code sticker in the manual pouch. This is all so confusing lmao.
    Once watched a video about something like this they said it’s in the trunk, like in the spare tire compartment. Yet to look for it. IMG_8014.jpg
    Jul 16 2018
    Atlanta
    It was in my warranty booklet, inside the front cover. But the PR code sticker will have the same month/year designation as the door jamb. There's nothing new to be learned from it in this regard.
