Hi guys,
I just bought a 02 A6 with the 3.0 and 128,000 it was showing misfires on all cylinders so I replaced all plugs and coils.That improved it but then i got a 17930 code for exhaust cam position sensor bank 2 so while I was waiting for the sensor to arrive i pulled the old one out and cleaned it up and swapped it with the intake sensor. Fired it up and it ran great so I decided to run it a few miles, after about 10 miles of cruising at 60mph I noticed it downshift and lose power, it shuddered slightly about like a misfire and had a bit of rattle. before I got stopped it had died. It did no over heat, there are no codes and the timing belt is good and tight oil level is good.
A 2ft bar on the crank will not turn it over.
Any ideas to what happened would be appreciated.
