    Jan 20 2016
    SW Wisconsin
    Remote programming help
    I have a 2004 A6 and have one old remote and two new remotes. Using VCDS I have only been successful at un-pairing all remotes. I have cleared out all existing remotes and performed the following with no success.
    [Select]
    [46 - Cent. Conv.] or [35 - Cent. Locking] (whichever is applicable to the car, as found here)
    [Adaptation - 10]
    Enter channel "01" (May be channel "21" in some Audi models).
    [Read]
    This will display the number of currently stored remotes in "Stored Value".
    Enter your total number of keys up to a maximum of 4(including any existing keys) in "New Value"
    [Test]
    Verify that the number in "Test Value" is correct.
    [Save]
    And have not been able to program any remote even the one that worked when I started the process. I only have one key for the car so I can't program them with the door. Any help would be greatly appreciated (My wife is not happy)
    Apr 13 2015
    United Kingdom
    Vcds remote matching
    I hope this info helps from VCDS:
    Remote Control Matching
    This procedure details how to match new radio-frequency remotes to many VW/Audi vehicles. This does NOT show how to match Immobilizer components, see other items on the Car Info & Procedures Page to do that.
    Procedure for matching radio-frequency remote controls to many VW & Audi vehicles:
    Check the Ross-Tech Wiki under Diagnostic Procedures for instructions specific to your vehicle.
    Gather ALL the remotes you would like to match. Insert one key in the ignition and turn it ON.
    [Select]
    [Adaptation - 10]
    [Read]
    [Test]
    [Save]
    Then press and hold (for at least one second) the UNLOCK button on the fob, at which time it will be learned. If you're programming more than one fob press and hold the UNLOCK button on the second fob for one second, press and hold the UNLOCK button on the third fob for one second, etc. You have a total of 15 seconds to do them all.
    The car may give you some sort of acknowledgement as each key is learned (lights flash, horn beep, etc.)
    If the above procedure does not work (neither Channel 01 nor Channel 21 are available), follow this procedure:
    Insert a working (old) key in the ignition and turn to the ON position (do not start car).
    [Select]
    [Meas. Blocks - 08]
    Enter group "003" (may be group "007" in some vehicles)
    [Go!]
    The value in field 2 shows how many remotes have been matched and in which memory positions (for example, "0001" indicates 1 transmitter in position 1).
    Lock the car from outside using the new, unmatched key in the driver-side door lock. You may need to hold the key in the unlock position while you do the next step.
    Press the UNLOCK button on the new key within 5 seconds often enough to reach next memory position (so, if the value in field 2 was 0001, you should press the new key's unlock button twice, to put the new key in memory position 2)..
    The car may give you some sort of acknowledgement as the button is pressed (lights flash, horn beep, etc.)
    Wait 5 seconds and press the unlock button on the new key to unlock the door.
    Turn the ignition key to OFF and remove the old key.
    Press LOCK and UNLOCK with the new key.
    Insert the new key in the ignition and turn to the ON position (do not start car).
    [Select]
    [Meas. Blocks - 08]
    Enter group "003"
    [Go!]
    The value in field 2 should now indicate 0011 in the example used, showing the old key still matched in position 1 and the new key matched in position 2.
    Make sure that new keys are always coded into free memory positions (where there is a zero in Group 003, field 2). If occupied positions (distinguishable by a "1") are used, the transmitter previously coded to this position will no longer work.
    In some cases, it may be necessary to clear out existing matched remotes using the following procedure:
    [Select]
    [Adaptation - 10]
    Enter channel "00"
    [Read]
    [Save]
    When the prompt asks if you are sure you want to save a value of 0 to Channel 00, click [Yes]
    After doing so, no remotes will be matched. You'll need to follow the appropriate above procedure to match all of the remotes.
    Jan 20 2016
    SW Wisconsin
    Thank you so much for the quick reply. I may have accidently misled you. When I started I had one working flip key and two new un-cut flip keys. I am well aware that I cannot program the IMO keys, but I can or should be able to program the remotes. Even if I can't program the new remotes if I can just get the old one that worked yesterday back, I'm happy. When I get to the step on the instructions where it says "Enter the number of keys you want matched" VCDS gives me a pop up box that says "enter the position of the key you want matched" I have tried both scenarios and get nothing. When I get to that step it seems no matter what I try nothing happens. Do I just need 2 cut keys? Or should I just keep trying and see if it finally takes?
    Apr 13 2015
    United Kingdom
    So you have no working keys and you have cleared out all of your key data from the system. If you have 2 keys with you, try putting one key in ignition and the other one in the drivers door lock according to VCDS:
    [Select]
    [Meas. Blocks - 08]
    [Go!]
    Sep 16 2010
    Central Wash
    Helps to go into MBV ...can't remember which one- and verify that the Lock Module is "seeing" the remote function. You can test each remote to make sure they're transmitting properly, good batteries etc..
    THEN, during the programming I found the key to making it work was this: When you have the remote you are trying to program, say it was #2 remote:
    , you should press the new key's unlock button twice, to put the new key in memory position 2..
    And if it was #3 remote you'd press the unlock button 3 times.
    It's odd that people can have trouble with this- I've owned a dozen modern VW's and Audis and programmed remotes for all of them and it always works.
