    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    Rear cross member question
    Hi All,
    Looks like the prior owner/shop left off the below cross member piece when putting on the Milltek exhaust, vs doing the ole' stack some washers to still make it fit. It's proving hard to track down the exact part number (believe it's 460-803-183-A) without having a real life picture of the part to compare against. Can anyone share details on this? Pic? Thoughts on how much of it is structural vs just protective? Other?
    Thanks much,
    Per
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    I believe it should be a "G" not a "6"
    4G0-803-183-A
    Looks like it is about a $50 part brand new.
    If it is structural, then it is likely too late and any damage that could be done with it missing has already been done.
    My guess is it is probably there to keep the driveshaft from hitting the ground if it should break for some bizarre reason.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jan 11 2016
    2016 A5 Cab, 2003 VW GTI 20thAE
    check out the image on the top of page 3 on this install diagram from awe.
    http://www.awe-tuning.com/media/pdf/...ust_system.pdf
    here's a pic of some spacers.
    [IMG][/IMG]
    Feb 17 2004
    2013 Audi S6
    Cheers, guys.
    Yes 'G' is it. Seems mostly protective, agreed, and perhaps in either direction: drive shaft coming down, 'stuff' coming up from the road. Nice spacers from AWE; might see if I can get just those from them.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    It is in no way structural, its nit hurting anything by not being in there.
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
