If you're planning on incorporating a vacuum-assisted accessory into your 2013+ A4 2.0T equipped with a metal intake manifold, you will need a reliable pressure reading from your engine. ECS engineers have again arrived at a simple, durable, and tasteful billet aluminum piece to suit your needs.
The ECS Billet Boost Tap fits in-line between your PCV hose and intake manifold, giving you up to 3 possible vacuum ports to tie into when needed.
Installation is a breeze and completely reversible since no modifications to the OEM components is necessary.
Tap Tap Tap-A-Roo
Fits:
Audi B8 A4 2.0T (2013+)
Be sure to check out our -----> Installation PDF <-----
Jason
