Results 1 to 34 of 34
    Jan 20 2016
    Marlton, NJ
    Newbie Help for an A6
    Hello All,
    I'm thinking of purchasing an '04 A6 (S-type or S-line, I think) 2.7T with 99K miles. But, I'm kind of hesitant because the owner stated the there's a "small" leak in one of the turbos from the oil feed. I don't know how much he's been driving it with the leak. Plus, a guy I know says that '04s a problem childs so to speak and that S-Type/Line weren't made that year. I apologize for being a newbie and if I posted in the wrong section. Thanks in advance!!
    Aug 04 2009
    Glen Ellyn, IL
    Howdy! You'd love the car if you buy it. 99k I good mileage and it's a nice executive sedan.
    First and best question is: will you be wrenching yourself and are you okay with about $200/mo in maintenance and upkeep? If you're okay with that then pretty anything that car will throw at you you'll be able to handle.
    It is an S-line and '04 I the only year the C5 was offered with an S-line.
    At that mileage the timing belt needs to be done if it hasn't been. If you can wrench it's easy to do in a weekend with about $300 I parts and about $50 for the cam bar and crank pin (don't try without it).
    An oil feed leak isn't a good thing and can be bad if it's a big leak. But unless he's POSITIVE it's the oil feed I'd consider that the cam plugs, cam chain tensioner on the passenger side or the back of the valve cover gaskets are leaking down onto the turbo hardware. These engines are pretty leaky and all the seals on the heads are real suspect.
    Feel free to ask any more questions. If you have any more details or pictures we can probably give some more pointers.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Senior Member Two Rings frankwizzle's Avatar
    Oct 08 2008
    Derby City
    Don't listen to that guy (that said 04s are problem child's), he doesn't know what he's talking about. The s line was only available in '04. It is a little more reliable as they have an updated torque converter seal, a very common and expensive issue with these cars. Some non s line models from late 04 also have the updated TC seal, you'd have to check the vin.
    A slight leak in the turbo means it's on its way out. Either the oil seal is bad or the oil feed line is leaking which will lead to oil starvation and turbo failure. So unless your ready to spend a few grand to swap/upgrade the turbos, you may want to move on.
    Sent from my Nexus 5 using Tapatalk
    Jan 20 2016
    Marlton, NJ
    Thank you both for your replies!! A lot quicker than the other sites . I'm kind of a weekend "wrencher" so to speak. Also, the check engine light is on and the owner stated that it was "only" the o2 sensor . He's also asking $2300 for it. I want the car and it's pretty clean.
    Aug 04 2009
    Glen Ellyn, IL
    That's pretty much a no brainer... if you have some money in the bank and a backup car if the turbo does go out then you'd do just fine picking it up. You can get fresh K03s for dirt and if you can wrench then pulling a motor and putting in K03s yourself won't cost too much.
    @fourings | Build
    Senior Member Three Rings Arsenal2012's Avatar
    Aug 20 2015
    Chicago
    Quote Originally Posted by br8knrun View Post
    Dude 2300? Is it manual? If you pass hit me up I am interested at that price!
    Sorry I cant help I am not familiar with the model or turbos.
    Aug 04 2009
    Glen Ellyn, IL
    No manual trans after 02 with the sedan and no manual S-line (so sad)
    @fourings | Build
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Quote Originally Posted by 4rings2turbos View Post
    I had a chance to buy a black a6 c5 s-line sedan, not avant. didnt buy because it was automatic. car was hot. sure, you can do a swap, but that wasnt in my plans.
    i elected to go for the 2000 a6 because of the factory 01e, despite the 158k
    Aug 04 2009
    Glen Ellyn, IL
    Facelift has its benefits for sure. But I can't see spending $3k for something I could find factory for 'free'. Just had to be patient when I bought my allroad.
    No S-line Avant ever but that would have looked cool. Narrow body 2.7T with those wheels and hatch spoiler. Mmm.
    @fourings | Build
    Sep 30 2015
    Oh wait, my mistake. I could have bought a saloon S6, thats what i meant. Usually the S6's are avants. I got the s-line confused with the s6 sedan.
    Aug 04 2009
    Glen Ellyn, IL
    I'm confused now, you mean C4? C5 S6 never came to the US in Sedan.
    @fourings | Build
    Sep 30 2015
    It may have been imported, that I do not know, but online, when i was looking for my c5, i stumbled upon a black, i believe 2004, S6 C5 in NY. The reason i remember the car is because every other S6 i saw was an avant, and this one was a saloon, or sedan. The car also had those big 19 inch RS6 wheels. Not sure if they are 19's but they were those sought after rims that many people get reps of because they cant find or afford the real ones. The catch was the car was an automatic. I believe it was the 2.7t engine with the automatic. Maybe the 4.2, I dont remember, so I cant say which motor exactly but I remember clear as day it was a black, automatic, saloon S6.
    Should have bought it just to show yall!
    It wasnt a fake because I paid like 3 bucks for a vin number search, car came back as a S6, not a rebadged A6.
    Ill try to find another one for you man. It was the real deal.
    Aug 04 2009
    Glen Ellyn, IL
    Hmm, that's crazy! I believe you for sure, but it's still a bit sketch. Would have been cool to own for sure!
    Engine aside though, it's so nice to row them yourself, right?
    @fourings | Build
    Sep 30 2015
    You mean the manual gearbox? Well to be honest with you man, I am just learning to drive a manual car properly. I learned to drive with my automatic b5. I have the general concept down, finding the gears is no problem. For me right now, figuring out the clutch pick up point and rev matching has been challenging. I literally drive like a grandma who just learned to drive when im in the a6. Not going to sit here and say I am the master of the stick shift. Not just yet.
    And I just looked online and you are correct, seems like the only S6's that were sedans were made for the euro market. The one I saw must have been imported at some point.
    Aug 04 2009
    Glen Ellyn, IL
    We've all been there! My first manual car (aside from a GTI I had for a few months like 8 or 9 years ago) was my current allroad. I could drive manual for years but I too wasn't very good at it. Had trouble matching up downshifts. But after 3 years I'm pretty good. Can shift crisply and quickly, rev match downshift, launch. Still have trouble with deciding what gear if I'm at higher speeds and I want to suddenly take off. But the situation comes up so infrequently that I might never get that down pat.
    @fourings | Build
    Veteran Member Four Rings R490's Avatar
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    Quote Originally Posted by a4kamila6 View Post
    I learned how to drive on a manual car, but still haven't mastered it yet. The clutch on these cars is really strange, I could shift much smoother with my old A4. The throws are also MASSIVEEEEEEEEEE with the 01e.
    2003 Audi S6 Avant
    2005 Audi S4 6MT SOLD, 2001.5 S4 6MT SOLD, 2001.5 S4 Tip SOLD, '00 A6 2.7t Quattro 6mt SOLD, '97 A4 2.8 Quattro 5mt SOLD
    Aug 04 2009
    Glen Ellyn, IL
    Agree with you there^ but I do find that I like the 'action' on it. Just a little notchy and the spacing is nice. Good box to be confident with.
    Anyone here driven a Porsche 914? The most hopeless gearbox ever haha. It's like playing Plinko finding the right gear.
    @fourings | Build
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    I've personally never driven a 914, but I'd love to have one some day. The later generation 911 SCs were also notoriously "interesting" to shift. You'd have to let the synchos rev up, too fast and you'd grind it.
    I'm a bit of a Porsche nerd, but have no time or space for one at the moment.
    2003 Audi S6 Avant
    Aug 04 2009
    Glen Ellyn, IL
    I have a huge soft spot for Porsches. A member on here with a B5S4 is coming over to use my garage at some point this winter. He has a 964 turbo and has offered to let me drive it :O
    @fourings | Build
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    I have an 03 with manual 6 speed
    Sent from my SGH-M919 using Tapatalk
    Aug 04 2009
    Glen Ellyn, IL
    Is it early 03? I'm curious. Maybe 03s did come with manual. Would you wanna give me your VIN so I can check the build date in Elsa?
    @fourings | Build
    May 22 2013
    Las Vegas, NV
    Sure. Wauld54b73n006893
    May 22 2013
    Las Vegas, NV
    Let me know
    Oct 08 2008
    Derby City
    There were 2004 manuals too. The cool thing about the manual BELs is that they use the old-style turbos/DPs so ko4s/k24s/etc designed for the b5s4 bolt right up
    May 22 2013
    Las Vegas, NV
    Not true
    May 22 2013
    Las Vegas, NV
    BEL you Have to change DPs. To fit the early style turbos
    May 22 2013
    Las Vegas, NV
    I know because I have removed mine and gone stage 3 oem rs6 turbos.
    Sep 30 2015
    APB engines had i believe the oval shaped down pipe flanges while the BEL engines had round or circular shaped down pipe flanges. It could be the other way around, but i know thats the difference, one is round, the other is more elliptical or egg shaped.
    Aug 04 2009
    Glen Ellyn, IL
    All manual engines had APB flanges.
    A6 sedan was really offered with manual trans in 03 and 04??
    @fourings | Build
    May 22 2013
    Las Vegas, NV
    Okay. I just went and looked and it does seem that they are the same.
    Weird you would know they all have the same flanges but didn't know they had 03 04 manuals
    May 22 2013
    Las Vegas, NV
    I think I remember going through this before. I bought some DPs from an s4 thinking they would work but reading the forums I thought they wouldn't fit. Then I just decided to go with the RS6s and would need new DPs anyway.
    Aug 20 2015
    Chicago
    All I want to know is what happened to the OP lol
    May 22 2013
    Las Vegas, NV
    Lol
    Established Member Two Rings CAL4.2's Avatar
    May 21 2014
    2001 Mustang GT 5-Speed
    Funny you mention it. I'm averaging $193 a month in maintenance/repairs after 2 years of C5 ownership which includes a mix of DIY and Indy Shop wrenching.
    Current:
    FOR SALE '02 Audi A6 4.2Q Tip (98k mi) Sport & Prem Packs, 18z 6Piston Fr Brakes|Bilstein|RS6 18x8 ET35|A/S 245/40|Gruvenparts)
    '01 Ford Mustang GT 5-Speed (135k miles):Coilovers & stuff (Bilstein|Stoptech|Porterfield|Maximum Motorsports|FordRacing|Michelin PSS)
    '03 Honda S2000:Totaled
    '05 Honda S2000:Sold
