Results 1 to 9 of 9
    Jan 18 2016
    Garfield
    High pitch noise need help!
    https://youtu.be/QGX9TFTmL38
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Dec 22 2015
    Chico, CA U.S.A.
    I have a similar noise coming from the cooling fan when it comes on. Is yours constant?
    Sent from my SM-N910V using Tapatalk
    Jan 18 2016
    Garfield
    Quote Originally Posted by Dillon Clark View Post
    No its only when I start the car it's like something needs to warm up and then you don't hear it again until the next startup
    Dec 22 2015
    Chico, CA U.S.A.
    Yeah same here. I'm thinking it's the bearings in the fan, once they warm up, the noise goes away. Something I'll definitely change when I do my timing belt, water pump, and thermostat.
    Jan 18 2016
    Garfield
    Idk about the fan but I'm thinking it's that little pump looking this under the turbo, I'm not sure what it's called so I can't even begin to research common problems associated with it...any ideas?
    Dec 22 2015
    Chico, CA U.S.A.
    Your problem may be different from mine then, cause I know mine is the fan.
    Established Member Two Rings StriktlyAudi333's Avatar
    Jul 20 2015
    Mesa, AZ 85207
    That's the secondary air injection pump
    Dec 05 2007
    ^This
    Active Member Two Rings Kyüshutsu's Avatar
    Jul 28 2013
    Minnesota
    SAI pump with probably cracked hoses
