Results 1 to 12 of 12
    Registered User Four Rings Phil@USP's Avatar
    Sep 18 2012
    Coral Springs, FL
    USP Motorsports | Spulen 1.8T and 2.0TSI Billet Spherical Catch Can Kits!!!
    Sep 22 2015
    KSA/VA
    Would the catch can alone fit with stock pipes since in your website you sell them alone and as a kit with pipes
    Sep 18 2012
    Coral Springs, FL
    Quote Originally Posted by drzero6 View Post
    What pipes are you meaning?
    Sep 22 2015
    KSA/VA
    I mean hoses and brackets
    Sep 18 2012
    Coral Springs, FL
    I am sorry, I am drawing a blank here on what you are asking.
    The hoses and bracketry of the kit does not interfere with anything from factory.
    Sep 22 2015
    KSA/VA
    True but you sell the spulen catchcan as a catchcan only... Then you have a spulen kit which includes the hoses and everything.... My question is, can i buy only the catch can and use existing hoses since i do not want the extra ports (methanol/boost) and hoses?
    Sep 18 2012
    Coral Springs, FL
    You can if the lines you have match up. So if its -10
    Phil
    Sep 22 2015
    KSA/VA
    I dont know, i have an S3
    Sep 18 2012
    Coral Springs, FL
    I think I understand what you are asking... No you cannot use just the catch can without the lines.
    The complete kit is needed in this case.
    Sep 22 2015
    KSA/VA
    Yaay, thanks for your patience
    Established Member Two Rings LOT4R's Avatar
    Jan 12 2015
    Chalfont, PA
    Q: Is this kit compatible will all aftermarket intakes? I ask this because it looks like there's a proprietary turbo inlet pipe.
    2015 Audi S3 Prestige: 3M Scotchgard Pro | H&R Spacers 10F & 15R
    Flickr
    Sep 18 2012
    Coral Springs, FL
    This kit will work with other parts but of course it was not designed to so some modification may be required.
