    Jul 03 2013
    new hampshire
    Control pump circuit low code, few ?s
    So I just got done replacing my timing chain, oil filter housing, fuel filter and a few other maintenance items. The car started right up ran great. I drove the car about 10 miles and it desided to stumble almost like it hit fuel cut. So I drove home, as I pulled into the driveway the car died and would not restart. The car did not have this problem before I changed the timing chain could it possibly be off a tooth. The only code I get from the solus is fuel pump module circuit low. Am I correct to believe that if the timing was off I should have a cam sensor code correct?. Thanks for any help you can provide
    Oct 24 2015
    Perth, WA
    Make sure there is no air in the fuel filter lines.
    My respray thread
    Jul 03 2013
    new hampshire
    I don't think it's a air issue as I was able to drive the car 10 miles. The car also will not restart or even attempt too. How would you bleed air out if it was in the system. I pulled the fuel pump fuse and allowed the car to run out of fuel before changing the fuel filter, could that have caused a issue.
    Oct 24 2015
    Perth, WA
    open the door a few times and prime it. I reckon you have air
    My respray thread
    Jul 03 2013
    new hampshire
    Ok definitely not a air issue, I removed the fuel line coming from the tank and I am getting no fuel from the tank to the high pressure pump. So I'm thinking either the pump in the tank is junk or I read there is a control module for that pump that could be bad. I checked all the fuses and their good
