Results 1 to 2 of 2
    Senior Member Three Rings rstein's Avatar
    May 20 2011
    Tail Light Bulb Refresh
    Had a blinker bulb die in my driver's side tail light so while I'm in there I might as well replace every bulb. Just checking to see if I have the bulb numbers correct:
    2X 7528 Bulb
    6X 1156 Bulb
    I'll be buying the LL (Long Life) Sylvania bulbs but will these cause any problems? Should be an easy swap right?
    While I'm tinkering, I also need to replace my windshield wiper fluid level sensor which as far as I can tell from DIY's is located behind my driver's side fender liner? Any DIY help on both projects is much appreciated.
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    Here's a page I keep bookmarked. It has all the bulb sizes for our car
    http://www.audizine.com/forum/showth...-S4-Bulb-Sizes
    Taillights are easier to remove in a sedan than an avant, but still easy none the less.
    The sensor is in the bottom of the washer fluid resivoir, which is indeed behind the driver fender/fender liner. Once you get the liner off you'll see it, piece of cake
    2002 Pearl/onyx S4 Avant
