I have a 2003 a4. I have no heat. I have changed the water pump,thermostat,and have flushed the heater core and cooling system. I will get some heat when I am driving at high rpm. I also noticed I am not getting coolant to the heater core. When I pull the top line off to bleed it I will get a small amount of coolant then it stops. The bottom line is hot. Any help would be great.
