    Dec 25 2014
    United States
    help apr stage 1 + ko4?
    i currently buyed a ko4 but my car have apr stage 1 thats its supoosed to work with stock ko3. will my car run fine?
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    From what I've seen of other users, yes, but it won't be optimal. Need a K04 tune and supporting mods.
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Get a MBC and run it in line with your n75 at a few psi lower than the k03 was running to be sure you don't lean out. You really need a tune to make it work 100%. When you're not in boost or low less than 5 lbs the car should run the same
    Sent from my SM-T560NU using Tapatalk
    SOLD the GOINHAM A4 ---> GT2860 Project
    Senior Member Three Rings UCFQuattroguy's Avatar
    Jul 05 2005
    '01 Audi A4 TMQ
    Orlando,FL
    Quote Originally Posted by GOODBYNAAIR View Post
    ^^This^^ Injector duty cycle on a Stage 1 tune is fairly high to begin with. Adding increased airflow will only require more fuel on top of that.
    My advice: Save up a few hundred extra dollars and get a proper tune. IIRC Motoza's K04 tune is around $400 FWIW.
    Dec 25 2014
    United States
    ill think ill have to buy a ko4 file then! thank for your responses ! 👍🏼
