Results 1 to 29 of 29
Thread: Aftermarket Sub
    Veteran Member Three Rings blubusdrvr's Avatar
    Mar 02 2015
    1970 LT1 Corvette, 2017 A4, 2001 996TT
    Maryland, United States
    Aftermarket Sub
    Does anyone know of an aftermarket sub-frame for this thing? Or someone who can make one? Chrome-moly? Billet? If not, can someone confirm that the A4/S4 is EXACTLY the same if I find a good used one.
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by blubusdrvr View Post
    where are you wanting to put the sub?
    FRRG AZ Ring
    Dec 04 2014
    my spaceship
    I liked the idea of replacing the OE unit on the rear shelf with something the same size but with a little more umpff, would be convenient having the battery in the trunk for wiring
    would be interested to see any info on this if it has been done
    Jan 15 2010
    Santa Barbara, CA
    JL Audio Stealthboxes work well for pre-fab units, but they aren't available for our car. Your next best bet might be a direct replacement for the OEM sub: http://www.audizine.com/forum/showth...ock-sub-woofer
    Apr 20 2009
    Orange County, CA
    OEM sub is free air so it and replacements will never quite match a sealed or ported setup. I wanted something easily removed that had an integrated amp so I want with an Infinity bass link. Install is really easy and sound is okay. Not audiophile grade by any means but much better than stock.
    Another option is to have a shop create a fiberglass enclosure that you can secure to the rear deck....but overall volume requirements would have to be tiny. And then you still need to wire up a separate amp, etc
    2007 Audi RS4
    Milltek exhaust//Stasis MS suspension//CPT control arms//TTRS steering wheel//JHM shifter/intake spacers//Apikol trans mount//034 diff mount/rear sway bar/endlinks
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    Quote Originally Posted by TypeRx View Post
    Were you able to use the stock wiring with that infinity sub?
    Apr 20 2009
    Orange County, CA
    Yes. Power is simple since the battery is in the trunk. For signal, you tap into wiring on the passenger side of the trunk. I posted a picture in the audio section here several years back
    2007 Audi RS4
    Apr 20 2009
    Orange County, CA
    But now thinking about it, I may have used line level converters from the stock speaker wiring. I vaguely recall the low level wire tap not working great.
    Bottom line, it's easy. Strongly suggest a small enclosed sub and amp with at least 100-150w true RMS, obviously more doesn't hurt.
    2007 Audi RS4
    Nov 05 2015
    Westchester NY
    Audio Integrations sells something for the B7 that I'm not sure will fit an RS4, but I've used their box in my STi hatch and it was perfect.
    http://www.audiointegrations.net/cat...76/8722954.htm
    Mar 02 2015
    Ummmm....I was actually talking about the front subframe not a beat box.
    Nov 05 2015
    Westchester NY
    now thats funny
    Veteran Member Four Rings Mistro's Avatar
    Jun 19 2011
    lol gold
    Veteran Member Four Rings musanoadsaba's Avatar
    Jan 24 2009
    2007 Ibis RS4
    Rockies
    Funny. Good thing I read the rest of this before I went out and starting taking pictures of my custom sub enclosure to post.
    Nov 05 2015
    Westchester NY
    Quote Originally Posted by musanoadsaba View Post
    Im pretty sure this is now an audio thread. Please post the pictures!
    Mar 11 2008
    B7RS4 & e46Ms
    HAHAH, that's my bad...
    to answer your question, no... what's wrong with your existing subframe? Are you running 034 aluminum subframe bushings?
    FRRG AZ Ring
    Feb 23 2010
    Nebraska
    ~ Matt J
    IG: @rsrtsvt
    '08 RS4 -- Suzuka
    991.2 GT3 -- Chalk (SOLD)
    '15 R8 V10 Plus (SOLD)
    '07 PB Audi RS4 (SOLD)
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by ad2330 View Post
    this thread is hilarious
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    Winnning
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Mar 02 2015
    It's starting to rust and wanted to start looking into options for the day I may need to replace it. Do you know the compatability of the A4/S4 sub with the RS? If I find a decent one in a part-out I may get one and toss it in the corner of the garage for a rainy weekend project.
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    I comprehended his question and saw people posting about sub moofers. Got very confused.
    My 2009 A4 Prem+ Build thread
    Jun 25 2009
    SC
    Hahaha this thread is awesome. Way to derail from the start koolade.
    Apr 20 2009
    Orange County, CA
    Lol, oops.
    2007 Audi RS4
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    Geez dood read the thread. JL Audio makes a great one ;-)
    Veteran Member Four Rings ryanhmusic's Avatar
    Aug 05 2014
    jack stands, a power washer, hand tools, bones of my fallen enemies, etc
    this has to be the greatest thread the rs4 section has ever had...
    I'm living for the day I can park something Italian inside of my house.
    I had one wild summer on match.com. -some jackass
    01100010 01100001 01101110 01100001 01101110 01100001 00001010
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by mpdbrown View Post
    I'm with this guy, on the derailment train post pics
    "Brake last, finish first."
    Nov 12 2015
    Oregon
    Lmao the first few posts I was trying to figure out wtf people were talking about. Good stuff. I like both. I'd love a tube sub frame and a custom sub box
    My build log
    Nov 05 2015
    Westchester NY
    Quote Originally Posted by VinnysS4 View Post
    Misleading thread title was misleading.
    Oct 02 2015
    B7 RS4, UrS4
    Boston
    this is great! Excellent read.
    OP, how rusty is rusty? I had my 1993 S4 apart last summer and after 22 years the front subframe, once removed, cleaned up perfectly after hitting a couple rust bubbles with a flapper wheel, etch primer, and enamel paint. And this car spent its entire life in New England, rust capital of the world. The alignment came out dead nuts on, and throwing in aluminum mounts completely transformed the car. I'd consider refurbishing the one you've got unless its bent, warped, or rusted through somewhere, somehow. Being less than 10 years old though, with the quality of materials Audi uses, i bet you're looking at surface rust and not malignant car cancer. Just my $0.02.
    Everybody else: Thanks for the audio tips, I've got a good direction to start in to add some nice low end to this anemic Bose system!
    Mar 02 2015
    Quote Originally Posted by lucidmatt View Post
    It's pretty cancerous. More than just surface rust. It still has a few years left in it but it needs to be replaced eventually. (so why not now) Sucks.
