Results 1 to 14 of 14
    Active Member Two Rings B5Mark's Avatar
    Jan 15 2016
    Colorado
    Replacing my turbos
    right now I have stock turbo's. I have excessive oil in my intercooler piping and what not. So im guessing that means the turbo's have broken seals?
    Since im most likely replacing the turbo's should I stick with KO3's or go up to KO4's?
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    That's just from your pcv system. Unless your turbos whine or the seals are shot and burn oil in the exhaust, you're fine.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Jan 15 2016
    Colorado
    Quote Originally Posted by CELison View Post
    That's just from your pcv system. Unless your turbos whine or the seals are shot and burn oil in the exhaust you're fine.
    You are sure? When I spoke with mechanics they have told me my turbos are shot. the car has 170k miles on it. not sure if the turbos were replaced before hand, I am the third owner.
    The car also "chokes" when you give the car full boost. at 4k RPM's it spits black smoke out of the exhaust (only when it reaches 4k rpm) and makes a popping noise. Any ideas?
    Feb 23 2010
    Emmaus Pa
    If you don't hear and whining from them in boost and no burning oil out of the exhaust they are fine. Oil in the ICs is normal. The choking and spitting out black smoke is from a rich condition. You're AFR is off. Could be a few things. First pressure test, you might just have a boost leak. Un-metered air escapes, afr is thrown way off, excess fuel (black smoke) and backfire is the result. Long story short, don't replace your turbos. I've probably done 10+ turbo swaps on these cars, I have a pretty good idea of the signs of a dead turbo.
    B9 S4- EPL/AWE
    Jan 15 2016
    Colorado
    Oh okay, but what im saying is that it isn't the normal amount of oil in the IC. More than usual. like i said excessive.
    Feb 23 2010
    Emmaus Pa
    put a number and unit on "excessive"
    B9 S4- EPL/AWE
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Listen man, no smoke out the tailpipe, no whine, you don't need turbos.
    Jan 15 2016
    Colorado
    Quote Originally Posted by Zba View Post
    I understand that but thanks.
    Nov 05 2009
    Denver
    Of course, you can always pay to have your turbos replaced and report back
    Jul 04 2012
    Woodbridge, VA
    Bahaha the mechanics that are telling you that you need turbos are the same ones telling you the amount of oil in the IC is not normal??? Hmmm.
    Jan 15 2016
    Colorado
    Quote Originally Posted by vavJETTAw36 View Post
    Lol thats why i always come to the trusty forum members.
    Im not going to touch my turbo's. thanks everyone.
    Aug 06 2008
    Canadia
    You should be able to find a trustworthy Audi shop to get a second opinion. Maybe your turbos are letting excessive oil through but it sounds like there are other issues to take care of first. An often overlooked part in the PCV valve because it's buried in the breather system, after changing mine oil consumption went from a litre between oil changes to maybe 1/3 litre if that
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Another unnecessary turbo replacement averted. Nice to see the community help each other out. Sad that there are shops that take advantage of people.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    I found oil in the intake track of my car way back in 2002 with 26k on it. Still OG stock turbos at 150k and it runs perfect. Some mechanics are stupid and some just want to get you to do work you don't need to do period.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
