Results 1 to 7 of 7
    May 11 2013
    bump stopper/dust boot
    Sigh, yes -- the bump stopper appears to be broken on my rear passenger side. The bump stopper is separated from the dust boot[?] so the rod for the shock absorber is exposed.
    Side note: It looks wet/oily because the car was driven in the snow before the picture was taken.
    Any idea what may have caused this type of damage? The ride overall is still fairly smooth, however I do feel a minor thump (or it could just be in my head) when going over certain surfaces like pothole covers that are receded into the pavement a bit.
    Is this part individually replaceable or it part of a larger piece of hardware? ECSTuning does have the OEM part for sale (highlighted in red for the S-Line suspension). Would this cause further issues if left unattended?
    Senior Member Two Rings torrque's Avatar
    Aug 25 2015
    Andretti
    I don't think you need to replace anything. I think all you need to do is suspend the car, take the wheel off, and push the dust boot on top of the rubber stopper. Find something to keep it on if it falls back down, I would even glue it on before I bother removing the shock for that.
    May 11 2013
    Quote Originally Posted by torrque View Post
    Hi torrque,
    From what I can tell, the bottom rounded out piece is completely torn off from the stopper -- mostly loose inside of the boot. With that said, would there be any adverse effects simply reseating the boot over the bump stopper since now it'll be shorter than the other 3 wheels? I do notice a weird thump when going over certain surfaces like pothole covers that are receded into the pavement a bit. Do you think this is a ripple effect of the broken stopper, or could it be a bigger issue?
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    I would check the shock out. Those stops don't just fall apart. How many miles?
    May 11 2013
    Quote Originally Posted by JayDog747 View Post
    Around 53,500.
    Aug 25 2015
    Andretti
    Nah can't be bad shock at 53k make sure it's right at both ends and check other suspension components..
    Sent from my SM-N910V using Tapatalk
    2016 Shelby GT350 Track pack - 6Gr wheels, otherwise stock
    2008 BMW 335XI sedan 6 SP Manual
    2001 VW Golf GTI VR6 5 sp Manual - Giac stage 1, intake
    Gone but not forgotten: 2013 Shelby GT500 .... sorely missed.
    May 11 2013
    I am planning on swapping out the torn bump stop now that it's starting to warm up a bit. I am fairly convinced that the odd thumping issue is a result of the bump stop being separated from the dust boot thus causing the "thump" going over certain surfaces -- the car drives perfectly otherwise. How difficult of a job would it be to simply replace the bump stop with a new one? I assume it will require full removal of the shock before the bump stop can be accessed? Will I need a realignment once a new bump stop is installed?
