Results 1 to 14 of 14
    Senior Member Three Rings Arsenal2012's Avatar
    Aug 20 2015
    Chicago
    My dilemma at this point is a cam shaft plug, I hope...
    So the day before yesterday it was about 6 degrees outside and I was driving on my way to watch the football games with some friends when I smell some burning oil.
    Thinking nothing of it soon enough smoke was billowing through my vents and polluting everyone around me.
    Ok no big deal, don't panic just pullover when you can, so I did about a quarter mile down the road.
    I popped the hood and let the smoke clear, at the same time I check under the car and see oil pooling on the floor.
    Greeeeaaaat!!!!!! I think one of the seals or gaskets I just replaced must not have been seated properly or it failed.
    Sooooo not having any tools but my Leatherman and with my balls slowly shriveling up inside my stomach I quickly check the oil and determine it safe enough to drive home(about 1 mile away).
    When I get home I grabbed some tools and removed the coolant tank and find this....
    A bit of oil allover the driver side.
    Are you starting to see my issue?
    Here's a bit of a better view...
    Finally you get to see the whole issue!
    So what do you guys think, I lost about half a quart from this, do you think it is my only issue?
    What would have caused this to pop out? My theory is the frigid cold contracted the material and the pressure caused it to pop out.
    Could anyone suggest advice to ensure this does not happen again?
    Thanks for looking and reading.
    Aug 04 2009
    Glen Ellyn, IL
    The block is far from cold. Maybe a bad seal, maybe not pushed in all the way. I've never heard of it happening before so I say just put a new one in (and from a better supplier than Blau, they've had some bad stuff in the past. Elring is OEM supplier and highly recommended) and I bet the issue doesn't happen again.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Veteran Member Four Rings SteelyS6's Avatar
    Oct 29 2011
    Winnipeg Manitoba
    I had a Victor Reinz cam plug leak badly two days after putting it in. When I went to change it, it literally fell out. There is an updated OEM Cam Plug with a lip on it. Have it in my hand and the part number I am seeing is: 078 103 113F
    Aug 20 2015
    Chicago
    Quote Originally Posted by SteelyS6 View Post
    I just did a search for this part but found nothing definitive. Do you have the product name?
    I ordered a VR replacement from eBay on Sunday, hopefully that one stays put, if not ill have to order something better, maybe what you suggested.
    Aug 04 2009
    Glen Ellyn, IL
    I know people have luck with other brands but because the 2.7T I I leaky I always go with Elring.
    @fourings | Build
    Aug 20 2015
    Chicago
    Ahh ok, its just OE.
    Thanks, if the one I have coming in pops out ill pick up the one you listed.
    Oct 29 2011
    Winnipeg Manitoba
    No problem, popped this one in dry and it actually was firm going in and no leaks since.
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    I know there are oe alternatives. But most dealerships give huge discounts on parts to forum users. I tend to buy most parts as OE now as the price is so close to aftermarket prices.
    But yea, i have never seen that before either. Weird.
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Aug 20 2015
    Chicago
    Well kick me in the nutz and call me sally!
    It happened again, to the same side with my new ring.
    I ordered a new elring about 3 days ago as a precaution ya know just keep it in the car incase and well I didn't even get that one in time so now she is out of commission again!
    I don't know what to do I guess this time im using Black RTV sealant I can believe this happened again FML
    Just yesterday I took a 2+ hour trip with no issues and today I take a 200 ft drive and its gone, couldn't find it either
    Nov 29 2015
    2001 Allroad
    Texas
    Do you have pressure building inside the block? After you get the new plug installed run the engine and pull the dipstick out a little and see if you are getting alot of air coming out.
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    might be time to get the updated oil cap and check your spider hose, too much pressure is building up
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Dec 16 2014
    Irvine, CA
    You have a PCV issue for sure. There is no way these should be popping out. Too much pressure in the crankcase that is not being vented.
    Aug 20 2015
    Chicago
    Quote Originally Posted by PaperToast View Post
    Thanks guys, ill look into the hose, ive already switched out the oil cap.
