Results 1 to 4 of 4
    Veteran Member Three Rings B7OrangeA4's Avatar
    Nov 27 2012
    South Jersey
    Weird headlight issue
    This morning I started my car and got right dipped headlight warning. Got out to see the passenger headlight was out. Shut the car off and on then got a left dipped headlight error, but the passenger headlight was working now. Restarted the car again and it went back to right dipped headlight, but driver side headlight was working. Fourth time was the charm and they both started working with no warnings. I checked the connections and they looked fine, but didnt want to dive into it in 15 degree weather.
    About two months ago I was driving when my exterior lights flickered off and my interior lights flickered on. It did it three times in succession. I brought it to a shop and they couldnt find any problems with the headlights or wiring and werent able to replicate it. It hasnt been a problem since
    Feb 24 2004
    Minneapolis
    Don't know what your shop did to trace out the wiring, but if you have good continuity you have to suspect the central electric module. That's what controls all the lights, and the bulb-out errors.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Nov 27 2012
    South Jersey
    Quote Originally Posted by mtroxel View Post
    I did a full vag com scan this morning after the issue and didnt have any new codes that code be related to the issue
    Established Member Two Rings p310b's Avatar
    Jan 15 2016
    Indonesia
    Try this
    http://www.ross-tech.com/vag-com/car...alignment.html
    I believe i had the same isaue before
