Though there are no shortage of solvents around I settled on the liquimoly engine intake decarb
Steps are nothing fancy - after warming up the car use a long (or short bit and extension) T30 torx and whatever socket wrench size (I used 3/8inch) you have take off the screw which holds on the intake air temp sensor
Pull off the sensor gently taking care not to damage the sensor and then insert the hose in as far as it'll go and just give it a short burst. Slowly pull the hose out giving short sprays each time. Don't spray for more than 5 seconds before the next step otherwise you may have issues starting up. Leave it for a few minutes to start its work.
Leave the hose in the hole and use your finger to create somewhat of a decent seal for the vaccum as per below while you do the below. (Gloves ideal)
Get your mate to turn on the car with the foot on the accelerator and Keep it revved up for to 2-2.5k rpm for about a minute. The car might hesitate starting and sound like it will stall. That is normal. While the car is on and your finger is keeping somewhat of a vaccum seal on the IAT housing spray the cleaner in short bursts while moving the hose in and out of the manifold. The car will hesitate and revs will drop a little however that is normal. The key is short bursts which will allow the cleaner to get in there and not overload the valves and intake with the liquid.
Do this until approx half the can is used up then turn off the car and again spray short bursts up to a max of 5 seconds starting from the hose all the way in and slowly pulling it out and again let it sit for a few minutes before repeating the previous step.
Once the can is used up, turn off the engine gently push the intake sensor back in, and reattach the screw being careful not to cross thread or over tighten. Just a little past finger tight is enough. Any more and you risk cracking the plastic.
Not sure on before or after from a valve perspective but if you look at the below picture of the hose (and this is after wiping) it at has probably at least dissolved
Happy cleaning!
