Originally Posted by
TheDarkness
curious to see more of your process and materials used to get your final results, looks great!
for sure. I didn't take a ton of pics. I usually don't because I get so laser focused on the task. I'll be better about it when I do all of the other interior trims. as far as materials:
*genuine alcantara from JPM coachworks. color 9040 jet black. 4 yards bought to cover majority of interior and door cards
*2 cans 3M 90 adhesive. I've read both good and bad reviews, but there were a ton of good. lays clear and followed the instructions to the t including a room setup to allow proper adhering and drying
*fine 350 grit sand paper
*metal scraper to remove old adhesive/fuzz from OEM fabric
*wide plastic putty blade to smooth out surface and work material from center to outer portions. eliminates wrinkles/bubbles
*a very, very thin foam to keep a smooth looking surface and great feel. really turned out better than I'd hoped
*xacto knife or, knife if x-act-zero if you've seen the Lego movie
*titanium sewing sheers
I think that's it. removing old material sucked a bit. took majority of my 5 hours. I pulled up one corner and just worked my way through the pillar trims. once I had those off, I used them to cut an outline in the alcantara. it helped to get close to sizing and also eliminated the waste of fabric.
I then scraped off old fuzz on the composite. sanded down just a very small tad to smooth it out. I then used the double bonding process on the foam, let it dry for about 45 minutes. then moved on to double bonding process for the fabric. it was very tedious I will say. but it saved me almost a grand that two nearby shops quoted to do the entire interior, and it urned out great. if you use the same method, I would say make sure you have the fabric exactly where it needs to go. once this 3M sets, it's a bi*** to get the fabric off. I wasted my very first cut out by laying it about 5 mm off kilter. after that, calm hands and focus and all others were very smooth. I really took my time planning and prepping for this. the fit and finish is incredibly important to me. done right, the result should last quite some time and have a great look. almost like wrapping the interior in a tuxedo.
I'll for sure post other pieces once I start working them on Wednesday. going out of town for work tomorrow or else I'd jump right into that.
cheers
