Results 1 to 12 of 12
    Sep 27 2008
    Phoenix
    When to replace coil packs?
    I'm about to hit 90k miles and my coil packs were last replaced around 20k. Would it be beneficial to swap in some new coil packs? Would this restore any performance, fuel efficiency, or provide an improved idle?
    Jul 18 2012
    New York
    Check them, if they look crappy or are an old version then yea replace them. If not leave them alone. As long as your plugs are getting decent contact from them you're okay.
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    They definitely should improve all the above only IF your current ones are that bad. Like the above poster mentioned, check them. You're not getting any misfires yet, so thats a good sign.
    If I were you, Id go and buy them to have them ready when you need them, especially if you're at 90k. They along with spark plugs are never a bad thing to have in stock.
    2008 A4 S-line 2.0T
    JHM Stage 2
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by Schweini View Post
    I'm on 170k miles with original coils. Audi never changed mine from the campaign they put out a while back. Maybe i should take it and get them replaced for shizzs and giggles
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    I would not replace them until you begin getting misfires. Regardless, purchase some coil packs, so you are prepared. I carry a couple in my trunk :)
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    I keep 2 extras in my trunk just in case. Seems one or two take a shit at least once a year. I have 80k miles.
    Oct 02 2006
    Wadsworth,OH
    As long as your vehicle is not missing and it runs strong I'd leave them alone. Though it would be a smart idea to pick up some spares to keep in your glove box. In the event you have one die attempting to limp it home can possibly cause more damage.
    I'd be more concerned about the health of your spark plugs.
    Jason
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    Quote Originally Posted by Sanjman View Post
    You should send those to audi and have them diagnosed, somethings wrong with them.
    Mar 18 2014
    Dunedin Florida
    Quote Originally Posted by allstock View Post
    Or put in the Audi Museum.
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    there is no way. not even lexus are that reliable to keep 170k on originals i don't belive that.
    Ivan
    Oct 24 2015
    Perth, WA
    I would replace them and keep the old working ones as spare instead.
    My respray thread
    Account Terminated Four Rings
    Oct 15 2013
    Quote Originally Posted by doughboy17 View Post
    this
