Results 1 to 4 of 4
    Dec 25 2008
    S4
    West of NY
    FS: 2000 Audi B5S4, Stage 3+, JHM's Shop Car, RS6 Turbos/Camshafts/Fueling, 434 AWTQ/412 AWHP (Dynosheet), 2.8L Rebuilt Heads, JHM Serviced (Receipts), JHM 01E 6-sp Rblt Tranny NorCal - Clean CA Title - No Longer Available
    Hi, selling my 2000 B5S4, Stage 3+, new RS6 Turbos & JHM Fueling, 6 sp manual, JHM Rebuilt Tranny, 2.8 ltr Heads, JHM large FMIC, 2Bennett Coilovers, etc. This was JH Motorsports ?Shop Car? that I bought in 11/2010 (I put on about 24K miles since 11/2010). JH Motorsports (https://jhmotorsports.com/shop/catalog/contact_us.php ) has all records for work done since 11/2010 (interested buyer can discuss S4 with me or JHM [Zendell or Dan]); I have all JHM receipts for work listed below and dynosheet.
    JHM?s blue B5S4 with their RS6 turbo kit (https://jhmotorsports.com/shop/catalog/jhm-rs6-turbo-kit-for-27t-p-18.html?cPath=21_56_60_100_30 ) went 10.8 in ? mile, and I have same RS6 setup: https://www.youtube.com/watch?v=JglEI7LqLP8
    I have dynosheet (see pics) from 034 Motorsports showing 433 awtq/412 awhp ? this Stage 3+ pulls hard to 25 psi; Devil?s Own Water/Methanol kit installed.
    S4 has 177,956 miles on chassis (but JHM recently installed 034 Motorsports complete replacement kit for all upper/lower control arms, tie rods, bushings, and S4 has new 2Bennett coilovers, sway bars, etc.) w/rebuilt 2.8 ltr heads, tranny, etc. I?ve spent $12,489 in last 5 years and have all JHM receipts ? see pics.
    Asking $13,900 or best offer. Located in Northern California (San Mateo, CA) 5 minutes from San Francisco International Airport (SFO) if want to fly in to see the car. Clean CA Title. Email [email protected] or 650-346-5167.
    (See 106 pics here: https://2000audib5s4forsalejhmshopcar.shutterfly.com/ including pics of CA title, 433 AWTQ/412 AWHP dynosheet, JHM receipts, etc.)
    Specifications:
    Engine:
    - Newer engine stock 2.7 ltr ? 94K miles installed by JHM with fully rebuilt 2.8 ltr heads (JHM rebuilt w/new valves, springs, and top end of engine resealed)
    - Vast RS6 Turbos with ARD bipipes
    - JHM RS6 Fueling Kit (RS4 airbox w/K&N filter, new 650cc Ev14 injectors, 4 bar fpr, JHM 90mm maf plus adapter, Hitachi Maf Sensor, JHM RS6 tune)
    - 034 Inlet Pipes
    - RS4 Fuel Pump
    - RS4 Camshafts
    - JHM large Front Mount Intercooler
    - Updated intake manifold and Spider hose
    - Vast Bipipes with 034 TTB
    - Upgraded Diverter Valves
    - Wiring Harness in good condition
    - Upgraded Spark plugs
    - New Coil Packs
    - Vast Water/Meth Injection Kit (uses windshield wiper reservoir to hold water/methanol)
    Exhaust:
    - 034 3? rs6 downpipes with 3? cats
    - Custom 4? catback with a 4? muffler and 4? resonator
    Drivetrain:
    - Newer transmission - stock 01E Transmission was rebuilt with JHM?s full rebuild kit
    - JHM 4:1 center diff
    - Vast Lightweight flywheel
    - Vast stg 3 clutch kit
    - 034 Motor mounts, 034 snub mount with cage, 034 trans mounts
    - Drive Train Stabilizer bar
    - Apikol rear diff mount plus carrier bushings
    - Newer rear diff ~ 70k
    - Shifter Trio Package
    - Stiffer Centering spring
    Suspension:
    - Custom 2 Bennett coilover system
    - Control arms (upper/lower) plus tie rods, bushings replaced with 034 kit in last 10K miles
    - Neuspeed Rear sway bar
    Brakes:
    - Custom 2bennett/JHM Brembo front Big Brake Kit 245mm
    - Extra Set of Track Pads
    - All stainless steel brake lines
    Wheels:
    - 18? OZ sl wheels w/new (only 3K miles) Goodyear Eagle F1 Assymetric 2 tires, 245/35 18
    Interior:
    - JHM adjustable in car manual boost controller
    - Trunk mount lightweight battery ? Optima Red Top Battery installed 1/15/16
    - AEM wideband
    - Custom Boost gauge
    - Interior still good condition (silver/white leather interior)
    Maintenance: (have receipts, and all work done within last 15K miles at JHM shop in Lathrop, CA)
    - New Red Top Optima Battery, new spark plugs , fresh oil change (Lubro Molly), air cabin filter, 650cc EV15 fuel injectors, 4 bar fpr, new front speakers, SRP pedals, 02 sensors, Y hose replacement, cam bore plug, spider hose, breather hose, intake hose, ignition control units, brake pads, p/s cooler kit, LCD screen pixel display fixed, egt sensor, door window regulator. JHM Weighted shift knob.
    List Date: 1/19/2016
    For more info, click here to view the original listing: FS: 2000 Audi B5S4, Stage 3+, JHM's Shop Car, RS6 Turbos/Camshafts/Fueling, 434 AWTQ/412 AWHP (Dynosheet), 2.8L Rebuilt Heads, JHM Serviced (Receipts), JHM 01E 6-sp Rblt Tranny NorCal - Clean CA Title
    This item is no longer available.
    Mar 12 2014
    BMW S1000RR
    Cuba
    car looks good but that dyno looks low, why only 412whp?
    Veteran Member Three Rings sfored's Avatar
    Dec 30 2004
    yeah meth 25 psi . that car should be doing 480-500 range ...w alll that HW
    Dec 25 2008
    S4
    West of NY
    It is now sold. Congrats to the new owner.
