Results 1 to 8 of 8
    Veteran Member Three Rings LEGO's Avatar
    Aug 20 2007
    SEATTLE, WASHINGTON
    Ko3/ko4 wastegate actuator
    Looking for a used but working wastegate actuator. Please let me know what you have. Don't need or want the whole turbo. Thanks!
    Established Member Two Rings B5Riches's Avatar
    Dec 15 2015
    Bayside, NY NYC
    That's not the valve by the turbo inlet but the round top and thin spindle? Sure I got one but I'm selling entire turbo oem born warner k03s for 150 obo I mean why not take the entire thing
    Sent from my SAMSUNG-SM-T337A using Tapatalk
    Aug 20 2007
    SEATTLE, WASHINGTON
    That's the one. I have a working ko4 but suspect the actuator has a rip in the diaphragm. Don't want to downgrade to a ko3
    1998 A4 1.8TQM MTM K04 5.82/034 415CC BT TUNE/GENESIS 415CC INJECTORS
    http://s22.photobucket.com/albums/b331/nelly11299/
    Sep 03 2011
    99.5 A4 Avant Quattro, 2000 GMC Sonoma
    Marietta, GA
    You should be able to test it with a hand vacuum pump or just pull the rod out and put your thumb over the hose nipple and see if it holds. I think I've got a couple actuators off of K03s if yours is definitely bad.
    Aug 20 2007
    SEATTLE, WASHINGTON
    Sent you a PM
    Aug 20 2007
    SEATTLE, WASHINGTON
    Still looking for one. Someone's got to have a bad turbo lying around they can pull the actuator off. Please let me know
    Active Member Two Rings boostinavants's Avatar
    Jan 24 2010
    98 a4 avant workhorse
    walnutport
    I believe I have one what's your zip for shipment price? Might have 2 actually
    Aug 20 2007
    SEATTLE, WASHINGTON
    Sent you a PM
