    Senior Member Three Rings Victor Newman's Avatar
    Oct 26 2014
    NC
    Clutch related - is this possible?
    Is it possible to have an oil leak at the filter, draining down onto the pan under the engine, and somehow getting into the clutch from driving? I'm talking a lot of oil leaked - like full filter amount. Possible?
    2010 S4 / 6MSG / Sport Diff / Alcantara Interior / StopTech 380mm BBK / Hawk HP+ / Castrol SRF / SRP Pedals / H&R Super Sport / VMR V710
    Jun 20 2015
    NC
    Oil leak like that can drain down and look as if its leaking from the clutch area. But as far as leaking down and then back up into the clutch isn't going to happen.
    Oct 14 2012
    Empty...for now...
    SE PA
    I had an oil leak from the filter housing because the o-ring did not seat properly when I reinstalled the filter housing. It drained down to the belly pan and ultimately dripped out onto the driveway. I do not see how it could get into the clutch area, though, as the bell housing of the transmission is bolted to the back end of the engine and there is, I believe, either sealant or a gasket at that flange interface which should keep out any foreign liquids or solids.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    i had an input shaft seal leak that I noticed on the belly pan & driveway & mistaked it for oil but it wasn't a ton and I doubt that's your issue.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    seems more plausible the rear main seal is leaking.
    There are 10 kinds of people in this world, those who know binary and those who don't.
