OK, so I tried the process 3 times, with the same order. On the 3rd try, I got the bar to slide back in with no force after a few rotations of the crank. Verified this 3-4 times after rotating the engine in between tries. Then I installed the crank pulley guard and crank pulley, and now it wont line up again.
Here is what happens:
Step 1: Rotate crank until TDC marks line up. Place lock bar on passenger side cam, rotate to horizontal position directly over the drivers side cam. Lock bar does not fit into drivers side cam.
Step 2: Remove lock bar from passenger side cam, place on drivers side cam. Now does not line up on drivers side cam.
Step 3: Rotate engine until lock bar is horizontal, and on top of the drivers side cam. Lock bar does not go into drivers side cam now.
Step 4: Remove lock bar from drivers side cam, place on passenger side cam. Now does not line up on passenger side cam again.
I found that the drivers side cam sprocket part that the lock bar goes into comes loose as soon as the bolt is loosened. No gear puller required. The drivers side always requires the puller to remove the sprocket part the lock bar goes into.
Any ideas? Is this normal?
