Originally Posted by
4ringnut
They 100% can. So for those of you who think you can avoid a TD1 by reflashing......you can't. Why? Because Audi of America now runs a backdoor scan when your car is plugged in at the dealer. The dealer has absolutely nothing to do with this. My service manager gave me the whole scoop. Apparently AOA realized that certain dealers wouldn't report TD1 to AOA, and would still do the warranty work regardless. So they decided to by pass the dealer in this process, and started running an automatic ecu scan when it's plugged in at any dealer, sending the info back to AOA. . But I just had my car in the dealer, and they didn't flag my car.........is what some of you will say. Guess what, you've been flagged, but the dealer won't tell you about it unless the car needs warranty work that would be related to the TD1. In which case you'll say, but my car is not tuned bro. And they will give you the AOA number to call. Enjoy.
This isn't necessarily true. You can avoid TD1 by flashing back to FULL STOCK, not stock mode. It worked for me 4 times at the dealer. My Allroad has been APR tuned for 55,000 miles. When you flash the car back to stock, the APR dealer can reset your flash counter. Some may say that a reset flash counter makes a car TD1 but that's just false. Something as simple as unplugging the battery to do stereo work can reset this. When you bring your car into the dealer for anything they run something called spec-actual....this means they plug your cars OBDII port into their audi diagnostic system to check for any faults, recalls, service campaigns, and to ensure that all ECM parameters are the same as they were from the factory. If any parameter is different, then a TD1 flag is automatically placed on your cars VIN. TD1 can also happen manually.... Some dealers are very strict about any type of modification to your car and its up the the shop to decide if they will manually flag you for something....some dealers have been known to flag for something as simple as an intake. You can't blame them though because they're in the business of making money. If they can find a way to reduce their financial liability, they will. I am friends with the shop foreman and a few SA's at my local dealer (who also tuned their A4s) so they told me all the ways around it. I also worked at an Audi dealer during college as a Sales Associate. Every dealer is different, but if your dealer is chill then you can often just ask your service advisor to not plug your car in when they're doing things like oil changes/ tire rotations. But as a rule of thumb, yes you can avoid TD1 on a simple stage 1 car if your tuner flashes to full stock and resets the counter. I did not have TD1 on my car until 75,000 miles at which point I stopped caring since their was no remaining coverage on the car. Usually you pay to play, but you can easily get away with it on a stage 1 car with no other mods
TD1 is probably the most beat to death topic on this entire site. Search audizine for it and just browse what others have to say/ have experienced
