Results 1 to 10 of 10
    Active Member Two Rings iandonovan's Avatar
    Aug 20 2015
    Wausau, WI
    Smelling gas inside car....
    Hey guys. My allroad just hit 100k, and recently I've been smelling gasoline inside the car, mainly when I have the heat on. Almost as though my fan is blowing the gas smell into the cab. I don't know why this would be but I'm getting worried. Its been pretty cold around here in Northern Wisconsin, in the negatives lately. The gasoline odor is pretty strong... Any ideas what this would be? Thanks
    Jun 03 2015
    Syracuse, NY
    Purge Valve sensor.
    Or SAI issues, or lines/evap can issues.
    Aug 04 2009
    Glen Ellyn, IL
    ^none of the above!
    Your fuel feed line crush fitting has contracted as is leaking. Look at the rubber feed line that attaches to the hard line/fuel rail above the passenger bank coming from the firewall. Run your car and you should see some wetness on the line or the valve cover below it. It's 17mm and you can tighten it down for a temporary fix. This extreme cold has made the metal shrink so much that it doesn't have a good seal anymore. It'll go away when it warms it but it's potentially dangerous.
    Your part number, sir: 4B0201541C
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    ditto for the fuel line, mine did the same thing last year when it got bitterly cold. if you want to be cheap or if you're in a hurry you can replace it with 5/16" fuel line and a couple of clamps.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    Quote Originally Posted by 4rings2turbos View Post
    ^none of the above!
    what he said
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Jun 03 2015
    Syracuse, NY
    To add to my wrong statements......
    Missing lug nut induce fuel smell.
    Bad Pringle pin
    What other advice can I give that is wrong lol..
    Aug 04 2009
    Glen Ellyn, IL
    Haha, not wrong still great advice. Just reducing his diagnostic time
    @fourings | Build
    Aug 25 2015
    Wisconsin
    Just took my car in last week for this exact issue (fuel line was f'ed due to it dropping below 0 last weekend ) and just found out HEET (i think?) helps prevent lthe pipe from gas freezing or something like that.
    Senior Member Three Rings bpark1210's Avatar
    Jan 08 2016
    PNW N. of Seattle
    Check for recall
    Recalls
    see details
    Fuel Tank Rollover Valve Nipple
    REPAIR NEEDED
    START DATE
    Apr 26, 2011
    AUDI ACTION CODE
    20L8
    DESCRIPTION
    The aging of the plastic material in the fuel tank rollover valve, combined with bending stress from the ventilation line to the rollover valve nipple, may lead to cracking of the nipple. If this happens, a fuel leak may result. Leaking fuel, in the presence of an ignition source, may result in a fire.
    NHTSA RECALL NUMBER
    08V197/11V267
    REMEDY
    To prevent or repair cracking at the nipple, reinforce the nipple on the rollover valve.
    http://web.audiusa.com/recall/
    Aug 04 2009
    Glen Ellyn, IL
    Give me your VIN and I'll check for open campaigns in ElsaPro. Probably not the issue though since it's a rollover issue only (fuel leak they speak of pertains to a leak in the event of a rollover. And it wasn't a cold weather issue.
    @fourings | Build
