Results 1 to 9 of 9
    Jan 18 2016
    oh
    Link to Common Turbo Upgrades? (Increase Boost Level)
    Hello,
    I recently bought a 99 Audi a4 1.8T quattro 5 speed with a blown engine. I've installed a replacement engine in the car with the intent to resell the car but I've realized how much I enjoy driving it.
    That said, I have some general newb questions but I haven't found a specific thread that answers all of my questions. It appears the wiki is down as well
    I'd like to get the most reliably safe amount of power from the stock turbo and components. This will be a daily in the winter. It won't be driven much during warmer weather. I want to keep it relatively cost effective. I'd like to increase the boost to the maximum amount the stock turbo and engine can reliably handle. Fyi turbo is in good shape (no shaft play) as well as the engine. Thoughts are a cheap manual boost controller to increase psi, suggestions? I know the ecu will need to be tuned (chipped or reflashed) to adjust fuel and timing to compensate for the additional boost. Which companies offer this and how much do they charge ballpark??
    Again I'd like to keep it very simple. Stock exhaust, stock turbo piping, stock intercooler. Maybe add an aftermarket blow off valve (diverter valve) and a boost gauge. Any suggestions would be helpful.
    Thanks
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Do some searching lots of info here you just have to find it.
    In a nut shell stg 1 tune + and new DV 18 psi 200 chp thats all you can do keeping it stock "ish"
    Some light reading to start you off -A-few-questions
    1 tuning option just to give you an idea Clicky
    SOLD the GOINHAM A4 ---> GT2860 Project
    Veteran Member Three Rings PringlesInVic's Avatar
    Oct 31 2015
    '05 Touareg V8, '11 MkVI Jetta TDI
    Victoria, BC
    As GOODBYNAAIR has suggested, the search tool is your best friend. You will have to do some digging through as the most popular threads with 900+ pages always come to the top.
    The FAQ in the Tech/DIY section is FULL of great info.
    As well, there are a ton of build threads on here which are worth a read. A lot of them will cover your questions before you ask them.
    With that said, my suggestion to you is to make sure all the maintenance is up to date on your car. These things can add up quickly and eat away your mod budget. But the proper maintenance will keep that car that enjoyable to drive.
    As for tuning, my car came with a tune. But if i didn't I would get a custom tune from a member on here named kOmpressed. From what I understand, bang for buck, he's the guy.
    And welcome to AZ. And congrats on the B5. We would like to see Pics.
    SOLD - '98.5 A4 1.8TQM - Aluminum Silver Metalic
    REVO Stage 1 - BW K04 - CTS Test Pipe - Milltek Exhaust - ST Coilovers - Hyperboost DV - ECS Snub - TFSI Coils/ICM Delete - eBay SS - Valeo SFW - DEPO Ecodes - 18" BBS Reps - OEM RS4 Grille - Alpine/Hertz Stereo - PODI Boost Gauge + POD
    Build Thread HERE
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    What I'd suggest is, stage 2 tune, exhaust 2.5. hfc or test pipe, n710 diverter valve or aftermarket forge ect. And a boost gauge. When clutch goes upgrade to a stage 1 or 2.
    You will probably want to replace the snub mount and the jhm shifter trio is a great feel upgrade. And a rear sway bar with decent coilovers.
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    My stock clutch didn't like kompresd stage 2 tune at 22 psi. 4th and 5th were useless under power. It did have 150k on it.
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    the first thing you should do is pay no attention to "stage"
    on a platform that is almost 20 years old...it can really mean anything right now.
    get a tune, new diverter valve and a test pipe/HFC (you can leave stock resonator/muffler)
    This is the easiest/cheapest way to get some more power on stock components.
    Sep 01 2011
    Louisville Kentucky
    K0mpressed is one fella here that does it, and I've heard a lot of great recommendations for him.
    Daz Dillenger is another person who does custom tunes for a very reasonable price, and easily comes just as highly recommended.
    You can send a PM to k0mpressed here on audizine, and I found Daz Dillenger's Facebook page very easily... Then you can send a message to him there.
    Oozed from a pustule of thought somewhere within the recesses of my mind...
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    This is one of the better noob guides out there
    http://www.audiforums.com/forum/b5-m...rmation-93439/
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Three Rings Sumo337's Avatar
    Jan 07 2015
    2011 B8S4
    Pittsburgh, PA
    I'm running with a F21 turbo, 21psi. 2nd and 3nd gears goes hard.
    @chetbagged
    2011 B8S4 Prestige
    460HP-384TQ Manual
    APR / ECS / P3 / WCI / Sportshifters / Polo Performance / Airlift / Caractere
