Originally Posted by
Chandler
You don't need the fancy tool, in fact there isn't an adapter in there that will fit... These pistons do not need to be spun like some other German vehicles.
boro92
+1. Let's not perpetuate incorrect ideas.
After the ebrake is retracted via vag com, the piston can be pushed in. Whether you use a c clamp, a screw driver or whatever doesn't matter. You don't use the piston compression tool that rotates like other ebrakes. That tool is only required if you do not use vagcom in this process
Chandler
Interesting. I was not able to use a tool without disabling the rear parking brake with Vag-Com - I even tried because I was curious.
Not sure if any of these were in response to the tool that I suggested, but if so please let me clarify: it is necessary to push the piston straight back into the caliper while the electro-mechanical parking brake is in the service position, but it is not necessary (and not recommended, or maybe not possible at all...?) to use the type of tool that rotates the piston as it pushes it back into the caliper. The tool I linked is simply for pushing the piston straight back into the caliper, not for rotating the piston.
Side note, but the face of the piston does have two or three little notches which would lead one to believe that the push-and-rotate type of piston tool should be used, but don't do it!
EDIT: If you try to push the piston into the caliper with the EPB in its normal operating position (even if the parking brake is disengaged), you should come up against a lot of resistance. Crank too hard on it and you may/will damage the system. However once you put the EPB in "service position" using VCDS or Carista, the piston will push easily into the caliper, just like your front calipers and any other standard (non EPB) brake caliper that you've worked on before.
