Results 1 to 3 of 3
    Veteran Member Four Rings A4_2.8tuner's Avatar
    Sep 16 2004
    1997 Audi A4 12v VRT (project), 2000 S4 stgIII, 2019 Nardo RS3, 2009 R8 gated 6spd, 2006 Lotus Elise
    St. Helens, OR
    Shifter issue-hard time getting into reverse
    I am having an issue especially getting into reverse. its near impossible most times. the car does have a short shifter, UUC I believe but am not positive. If I turn the car off, it typically can get into reverse and through gears. It seems to be the most difficult when the car is on and I'm trying to reverse into somewhere. I have tried messing with the adjustments on the shifter assembly, but to no avail thus far.
    Does anyone have any thoughts or heard of this before? Thank you.
    Instagram: brianbement
    EUROTUNER Feature-November 2009 http://www.superstreetonline.com/fea...-1997-audi-a4/
    Current Fleet: 1997 A4-Eurotuner feature car & current VRT project, 2000 S4 stage 3, 2017 Vegas Yellow S3, 2006 Chrome Orange Lotus Elise
    Senior Member Three Rings millerchris85's Avatar
    Jul 27 2012
    C5 S6, Mk6 Golf R
    Minnesota
    May need shifter adjustment (setting angles in the car - JHM's shifter install describes it).
    Or, reverse was occasionally hard for me. I would put it into 2nd and then it was easier getting into reverse.
    2002 S6 6MT
    2013 Golf R Stage 3
    Veteran Member Three Rings Heavy Winter's Avatar
    Jan 27 2013
    Boulder, CO
    It's most likely how you have it adjusted, given that you can find all gears when the car is off.
    The PO of my avant had installed a UUC short shifter and it was nearly impossible to get the car into reverse.
    After a ton of time trying to adjust it to get it to work I said screw it and went back to stock.
    No issues since then. And maybe you can find the sweet spot. . .
    I just wanted my car to work.
