Results 1 to 18 of 18
    Established Member Two Rings Grenalis's Avatar
    Apr 29 2013
    St. Louis, MO
    Cooling System Part Number Request
    Good morning Audizine,
    This topic is a request for a part number for a cooling system part.
    On my 04 A4 B6 1.8T Quattro, I have a part that is leaking, and I would like to get a replacement, just in case in the event, that once I remove it, and it is cracked, that I will have a replacement.
    The part is located on the drivers side front of the engine, is plastic, and appears to be attached to the block via 2 bolts.
    If anyone could supply me with the part number, and if possible the name of the part, so that I may get one ordered, I would be greatly appreciative.
    Thank You Audizine
    2004 Audi A4Q B6 1.8T
    5 Speed Tiptronic
    Dolphin Grey
    Stock FTM
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    Thermostat housing part # 06B121111K. Also replace the j-plug if you are replacing the thermostat housing, part # 06B103033A
    Apr 29 2013
    St. Louis, MO
    Thank you very much crazyquik, much appreciated. I do have 2 questions now. Does the t-stat housing have a new t-stat? Is the J-Plug near the t-stat housing?
    5 Speed Tiptronic
    Dolphin Grey
    Stock FTM
    Jun 30 2008
    Erie, Pennsylvania
    I'd recommend this nice kit that ECS put together. Has everything you need, including the oft forgot hard-pipe o-ring.
    https://www.ecstuning.com/Audi-B6_A4...tat/ES2574945/
    Oct 23 2010
    2004 Atlas Gray A4 Avant
    Cranberry TWP, PA
    That kit includes a Vemo (non-OE) thermostat, so YMMV on whether it'll start leaking within a year or not. Stick with OE/Behr/Mahle when it comes to the thermostat on these cars...
    2004 Atlas Gray B6 Avant, built 2.7T w/ BB K24's on E85
    2005 Touareg 4.2 gas guzzling daily
    2002 Triumph Daytona 955i
    1997 BMW M3 Coupe (sold, sad reacts only)
    Jan 30 2012
    Brunswick, Ohio
    Quote Originally Posted by Steve Bassen View Post
    Ya it's a hit or miss with these thermostats. I agree for the extra money OEM is the best option by far and will likely last a good 60k miles or more. Some have had good luck with the aftermarket brands and alot have also failed soon after install.
    Quote Originally Posted by Grenalis View Post
    Yes the thermostat housing is the whole assembly which includes the thermostat which is part of the assembly. The j-plug is right next to the thermostat. It is held on by 1 13mm bolt. They usually crack and cause a leak. If when you remove it you see that it is in pieces make sure to inspect you water pump as well to see if the piece(s) that broke off hit the pump and damaged it. Also you will need the o-ring for the water pipe. Part # WHT006407. If you get a kit from ECS like walky suggested it comes with the o-ring and j plug already.
    Jun 30 2008
    Erie, Pennsylvania
    ECS's kit used to include the Behr stat, but they must have switched to the Vemo unit at some point. Anyway, they do have a kit made up with the OEM t-stat as well:
    https://www.ecstuning.com/Audi-B6_A4...tat/ES2587731/
    Apr 29 2013
    St. Louis, MO
    I just looked @ the car this morning and compared what that part looks like, and it dosn't look the same as the part above. It does not have the part that has the hole next to the bolt hole, or the outlet that looks on that part to connect with a hose clamp. I also could not locate that J-Plug. All it has is the part that mounts to the block, the sensor, and the outlet that connects to the cooling hose via the hose sliding on and the clip to hold it in place, that is right next to the sensor. Any Ideas?
    Thank You Audizine
    5 Speed Tiptronic
    Dolphin Grey
    Stock FTM
    Jan 30 2012
    Brunswick, Ohio
    Thank You Audizine
    The part above is there. It is on every b6 1.8t. It is hard to get a good look without removing some things. When you change it you will need to remove the accessory belt from the alternator, unbolt and remove the alternator (don't forget to disconnect battery), remove intake tube going from throttle body to intercooler, unbolt and remove throttle body, unbolt 13mm bolt that holds water pipe to throttle body. After you remove all of that you will be able to get a good look at it and do the repair as needed.
    Apr 07 2011
    This is what the thermostat looks like installed on our cars. It's under the intake manifold.
    Apr 29 2013
    St. Louis, MO
    Okay Im an idiot. I broke out my trusty mirror and looked up under the intake plenum and found the tube and hose. Thanks you Audiziners for the reassurement, that it is in fact the correct part.
    5 Speed Tiptronic
    Dolphin Grey
    Stock FTM
    Apr 07 2011
    If yours needs replacing, here's a writeup. Click
    Oct 02 2006
    Wadsworth,OH
    Vemo Q+ is actually the OEM piece it just has the Genuine markings filed off.
    Vemo Q+
    Genuine Audi
    Jason
    Established Member Two Rings B5Riches's Avatar
    Dec 15 2015
    Bayside, NY NYC
    Oh I tho it was the coolant flange
    Apr 07 2011
    The coolant flange is located on the rear of the engine right in front of the firewall. This is what it looks like back there.
    Apr 29 2013
    St. Louis, MO
    Anyone know the part number for just the o-ring that connects the metal coolant tube to the thermostat housing?
    5 Speed Tiptronic
    Dolphin Grey
    Stock FTM
    Jun 30 2008
    Erie, Pennsylvania
    Yes. It's N90365302.
    20mm x 3mm is the size.
    Apr 29 2013
    St. Louis, MO
    Thank you so much WT
    5 Speed Tiptronic
    Dolphin Grey
    Stock FTM
