Results 1 to 7 of 7
    Nov 19 2015
    Philadelphia, PA
    Question Everything is Fault Code - '13 Audi S4
    Hey everyone!
    I got my CPO 2013 S4 the last week of November. Was ecstatic about the car and enjoyed the hell out of the first week. On the 8th day Philadelphia welcomed the car with a rear end collision by a trolley and since the car's been in a body shop repairing the damage to driver side suspension plus subframe, wheel, quarter panel and rear bumper. I got the car back yesterday and noticed a few things missing/not working.
    - Keyless entry not working. So when I'm at the door I can't unlock or lock the car by the door handle button or sensor.
    - Side assist not available. Going through MMI the option of side assist says it is currently unavailable.
    - Rear parking assist does not have audible tone when you get close to an object.
    - Hill assist is no longer working At hills I roll back without the second or two pause before the brakes disengage.
    - Certain FM channels are coming through with a lot of static and distortion.
    I used my Carista app and dongle to run for fault codes and it mostly everything that has to do with the rear left side, the side the damage occurred. Check it out:
    ***TL:DR Version below codes
    CAN network gateway
    Part #: 8R0907468J
    Coding: 80C303FF00 (hex)
    Component: GW-BEM 5CAN-M
    Fault codes:
    02001 Data-Bus Automatic Distance Regulation
    00384 Optical Databus
    Ignition authorization
    Part #: 8K0907064GM
    Coding: 0F814000000000000000 (hex)
    Component: BCM2 2.0
    Fault codes:
    00192 Door Handle Touch Sensor rear-left (G417)
    Central electronics
    Part #: 8K0907063DJ
    Coding: 26000091863CAFE0240048C300003D0D0F9C9308A209022100 0008000000010200020030000000 (hex)
    Component: BCM1 1.0
    Fault codes:
    02070 Rear Parking Aid Sensors
    Body/convenience system
    Part #: 8K0907064GM
    Coding: 0106023A00FA404580B0013200000000 (hex)
    Component: BCM2 2.0
    Fault codes:
    02742 Left brake / turn signal lamp
    02743 Right brake / turn signal lamp
    01518 Bulb for Back-Up Lights, Left (M16)
    01519 Bulb for Back-Up Lights, Right (M17)
    00985 Right Tail Light (M2)
    02198 Connection 9 (in Seat Wiring Harness Left)
    02199 Connection 10 (in Seat Wiring Harness Left)
    00984 Left Tail Light (M4)
    03532 Lamp for Brake- and Flash Light 2 left
    03533 Lamp for Brake- and Flash Light 2 right
    01503 Bulb for 3rd Brake Light (M25)
    Rear left door
    Part #: 8T0959795Q
    Coding: 010C13204000210001 (hex)
    Component: TSG HL
    Fault codes:
    02123 Door Warning Light / Entry Light
    Parking brake
    Part #: 8K0907801K
    Coding: [none]
    Component: EPB-4
    Fault codes:
    70912 Manufacturer-specific code
    71168 Manufacturer-specific code
    ABS
    Part #: 8K0907379CK
    Coding: 281D1A (hex)
    Component: ESP8 quattro
    Fault codes:
    00473 Control Module for Electric Park- / Hand Brake (J540)
    02214 Tire Pressure Warning
    Steering angle
    [failed to connect]
    All-wheel-drive system
    [failed to connect]
    Engine
    Part #: 8K5907551E
    Coding: 0A190034052600060000 (hex)
    Component: 3.0l V6 TFSI
    Fault codes:
    P177F Manufacturer-specific code
    16985 Internal Control Module, Memory Check Sum Error
    Adaptive cruise control
    [failed to connect]
    Lane-maintain system
    [failed to connect]
    Lane-change system
    [failed to connect]
    Radio
    Part #: 4G0035082D
    Coding: 020007010000000001 (hex)
    Component: Radio U SIRIU
    Fault codes:
    02983 Connection between Impedance-Converter 1 and Disc-Antenna
    02984 Connection between Impedance-Converter 2 and Disc-Antenna
    Infotainment system
    Part #: 8R1035746B
    Coding: 110200000206A1EF55028B4E00000403140000000000000000 (hex)
    Component: H-BNT-NA
    Fault codes:
    02067 Optical Databus Unauthorized Awakening Request
    03157 Function Limitation because of Communication Failure
    *TL:DR -
    So with my little knowledge of these fault codes is sounds like the shop either doesn't know how to follow a wire diagram or something else is missing/also damaged. I was reading a different forum post on Side Assist not working...
    http://www.audizine.com/forum/showth...e-this-problem
    ...and forum member kdub mentioned that Side Assist won't work if a sensor is bad, which sounds plausible.
    Anyone able to diagnose those codes better and come up with a scenario to all the faults? I'm sending the car back tomorrow and the shops going to take it to Audi.
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    With that many faults, your best bet is to let Audi fix it. It sounds to me like the body shop has no idea how to work on Audi electronics. It's best to have someone that specializes in Audis (the dealership) fix a problem this extensive.
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Mar 21 2015
    Did you by chance scan anytime before the accident?
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    It looks more like they unplugged or replaced a lot of things and it may just need to be programmed and/or cleared.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Nov 19 2015
    Philadelphia, PA
    Luckily I overestimated the possibilities of what could be wrong and the shop hadn't reprogrammed everything. Thanks guys!
    Mar 05 2014
    2020 SQ5
    PDX
    Quote Originally Posted by LittleBlueBox View Post
    And they gave it to you that way without even letting you know? Wow. That is some serious B.S if that is how it went down, also speaks very negatively towards their work. Again if that's how they operate, you need to verify all of their work if possible.
    Nov 19 2015
    Philadelphia, PA
    Dakkath - That's what got me about the situation. It was a family friend's shop who does work with a local Audi Dealer. Body and all looks fantastic like nothing ever happened but it's those details that were missed that assures I won't pass along the name.
