Parts used:
- Lenovo Windows Yoga 2 Windows 8.1 Tablet with 8” screen
- Rosstech HEX-USB+CAN cable
- OTG USB 2.0 to microusb dongle (since tablet only has a microusb port)
- 3M dual lock reclosable fastener (type 400 stem density) to mount tablet to MMI shelf
- Cable clips (to neatly run rosstech cable out of harms way)
- OBDII Cable Extension to relocate the Rosstech cable safely away from the dead pedal. I use the splitter version because I also run a P3Cars vent integrated digital display.
I chose this particular tablet because:
- The hinge makes a convenient mounting point and conveniently folds down to view the MMI display.
- The screen resolution is retina quality (1920x1200 or ~283 PPI)
- The touchscreen uses anypen technology (anything metal like a ball point pen, or paperclip will work as a stylus). Due to the small screen, a stylus is essential for precise menu selection, or long coding in VCDS.
Some tips and observations:
- I used the default MMI splashscreen as the desktop wallpaper for the OEM look.
- Scale the text size to 250% on the tablet so the VCDS screen will fill the desktop.
- Confirmed that I cannot run VCDS and P3Cars display at the same time.
- Not enough power from OBDII cable to charge the tablet.
- Screen is very readable in bright sunlight.
Parts:
Tablet mounted on MMI shelf:
VCDS screen in daylight:
Screen flipped down to view MMI:
