Results 1 to 3 of 3
    Aug 10 2015
    RIP 3000GT VR4 w/15g's
    Dorr MI (Grand Rapids Area)
    Talking DTC 1606 after new seat bottom. Help.
    Car 2000 a4 atw add 5 speed.
    I installed a new seat bottom on the drivers side. Cut and soldered wires for head seat and air bag. I also had the front breaks and outer tie rod ends off trying to chase down a "cluck".
    Im not worried about the cluck right now. I need to find out why the ABS light is on and the brake light is blinking.
    Tryed to reset with vag-com but code comes right back. I have checked the ABS sensors and they apper to be good and not pushed in the far.
    Could I have screwed something up under the set when soldiering the wires?
    Never had code before doing the seat bottom & pulling front breaks off.
    Any help would be greatly appreciated.
    Good news is my drivers side heated seat works now.
    Aug 10 2015
    So I took my ABS module apart to check the connections that commonly fail, turns out it has been rebuilt by module masters (had a sticker on the inside plus jumper wires) prior owner must have had it done. After that I checked the number seven fuse and it's good.
    I checked the large fuse under the dash near the relays and it's blown. Will be gettin a replacement soon.
    Hoping putting the new fuse in will solve the issue.
    I got a felling its just gonna blow again.
    Will update once installed.
    Veteran Member Three Rings PringlesInVic's Avatar
    Oct 31 2015
    '05 Touareg V8, '11 MkVI Jetta TDI
    Victoria, BC
    Fingers crossed its just your fuse. And it doesn't blow again. Possible you shorted it out when wiring seat? Did you disconnect power from battery when you were working?
    SOLD - '98.5 A4 1.8TQM - Aluminum Silver Metalic
    REVO Stage 1 - BW K04 - CTS Test Pipe - Milltek Exhaust - ST Coilovers - Hyperboost DV - ECS Snub - TFSI Coils/ICM Delete - eBay SS - Valeo SFW - DEPO Ecodes - 18" BBS Reps - OEM RS4 Grille - Alpine/Hertz Stereo - PODI Boost Gauge + POD
    Build Thread HERE
