Results 1 to 23 of 23
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Ecs tuning cup kit vs Bilstein cup kit
    Newbie here,
    Wondering if anyone had a comparison on these 2 suspension kits and which is the better option. For the ecs kit I will opt for the oe sport spring kit. In Maryland we still have bad winters and wouldn't consider coils. I'm the type of guy to set it & forget it and I could use the remaining $$$ for an AK. Thanks in advance.
    Jun 19 2014
    toronto
    The b12 cup kit has the superior shock. Having owned and raced on both koni yellow and bilstein sports, my pick goes to bilstein. But koni you can set rebound stiffness to your liking. Your call on that aspect. Imo the bilstein is the more quality choice.
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by boro92 View Post
    I think ECS offers their "cup kit" with the Bilstein B8 sport shocks with the difference at that point being the H&R springs in the ECS kit and Eibach springs included with the Bilstein Pro-Kit.
    ECS "cup kit": https://www.ecstuning.com/Audi-B8_S4...its/ES3010022/
    Bilstein Pro-kit: https://www.ecstuning.com/Audi-B8_S4...its/ES2983800/
    http://cart.bilsteinus.com/product/46-183330/378343/AWD
    There are probably 3-4 things to consider....
    1. Can you get the Bilstein Pro-Kit? When I looked into it, it was at least a 3-4 month wait at every place I checked. ECS shows April 14th. There was a place on here the other day saying they could get them, but I don't know if they actually have them in stock. http://vag.excelerateperformance.com...i-1735908.aspx
    2. Price- The Bilstein Pro-Kit looks like it runs around $800 where the ECS assembled kit runs around $1000.
    3. Ride height- By all accounts the Eibach springs with the Pro-Kit is a pretty mild drop. Maybe around an inch on the S4 (they say 30mm/35mm, but by all accounts it is less than that in most cases). Obviously the ECS/H&R option gives you more ride height choices since you have 3 spring choices.
    4. The B12 pro-kit was designed for the 3.2 A4, so you're likely to get spring rates better suited for the A4. At the end of the day, this probably isn't a huge difference. The H&R spring rates are basically the same as a stock S4 according to what they told boro.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Jun 19 2014
    toronto
    Oh my bad. Didn't even click the link. Just assumed ECS cup kit was koni's. The old H&R cup kit was paired with koni's!
    If both are on bilsteins, jran is right. The shock is going to work with either spring setup. Pick your chosen amount of drop!
    If you are after a more dramatic increase in performance, you can get the bilstein shocks alone and RS5 springs. FWIW. But that will only get you about a half in drop.
    Note that some bilstein shocks have adjustable spring seats--where the spring seat can move up and down -- the shock body has a few presets where the seat can clip into. If they have that on the S4 version, then you are able to play with the front ride height. FWIW.
    see pic for adjustable spring seat:
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    I'm running HR OE's and Bilstein B8 shocks... very happy with the set up.
    Can't compare with the other kit though sorry...
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    I ordered the B12 kit in early December from AWE Tuning, they had the kit on sale for less than $700 so I had to jump on it ($716 regularly). They said expect 8-10 weeks to get here, also mentioned they had one "on the boat" that was unclaimed so maybe I'm getting it a bit sooner than usual. I've always ran Eibach springs on previous cars and always loved them for the comfort and performance.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Sep 15 2013
    MD
    Thanks everyone for the input. Essentially the pro-kit will have a "rake look " based on the measurements provided. I believe the census would prefer the ecs kit with h&r springs overall which I noticed the majority using here besides coils. I would love the drop on the sport springs but unsure how the ride would be for a daily driver . Including the winters in Maryland .
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by A.C. View Post
    I wouldn't necessarily trust the specs listed online. I'd recommend searching for a few people running the setup, and look at their pics. I've found the specs listed by the manufacturer to usually be off by a bit. I can tell you the Bilstein/H&R OE combo has a slight rake (there rear appears to be slightly higher than the front).
    Sep 15 2013
    MD
    Quote Originally Posted by jran76 View Post
    Good to know and thanks for the input. I'm leaning towards the H&R/Bilstien setup from what I've been researching online. I've heard pros and cons with Koni FSD Kit.
    Sent from my mind
    Oct 02 2006
    Wadsworth,OH
    If anyone has any other questions regarding cup kits let me know, I'll be happy to help!
    Jason
    Mar 18 2011
    Chicago SW Suburbs
    Any difference if I buy the ECS kit vs buying the springs now and then upgrading the dampers when needed (unhappy with ride, dampers reach end of life, etc.)?
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Newbie here,
    Hey buddy,
    Let me know what you decide to go with. And where are you from in Md, if you want to PM me that just PM me. I want to do some sort of suspension but I don't want to go to low since im still in a new construction area for where I live. They wont put the finishing top coat of pavement until probably next year sometime. I don't want to have issues with hitting manhole covers and such.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by AA S4 View Post
    More labor/personal time. If it were me I would rather do everything all at once rather than remove the suspension 2 times. Not to mention if you don't have the ability to work on your own vehicle you'll be paying for labor to install the springs/alignment and again later on down the road for shocks/alignment.
    Jason
    Mar 18 2011
    Chicago SW Suburbs
    I'm typically a DIY guy - is this a difficult install? Do I need a spring compressor if I buy the kit?
    When I did the STI swap on my Forester, the suspension drooped enough to slide the springs and struts in without much fuss.
    2013 S6 Estoril, Innovation, LED, Carbon, Roc-Euro, EPL Stg 1
    Oct 02 2006
    Wadsworth,OH
    Not the hardest thing in the world but I would definitely suggest a spring compressor.
    Jason
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    In general, the front is kind of a pain in the ass compared to other cars I've worked on, and the rear is super easy.
    Getting the spring on the front really requires the spring to be slightly compressed. The rear either needs a spring compressor to fit it in, or you need to slightly lower the subframe or manhandle the spring bucket to get it in (use leverage to push it down while you put the spring in).
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Bilstein with Eibach, end thread.
    Sep 15 2013
    MD
    Quote Originally Posted by chaos2984 View Post
    Hey buddy,
    No worries I'll post here. I'm located in Waldorf. Let me know when you want to gtg. Looking to get the suspension before spring. I intend to include adjustable upper control arms. It seems to be the norm with the Audis. I'm quite sure someone will chime in to confirm.
    Sent from my mind
    Jan 14 2009
    pasadena md
    Sent from my mind
    Yea sounds good. Im around BWI airport. We hang out on Friday nights at a local DD usually grab some dinner near by and head to DD for some coffee and chatting. There are a Few S products and 2 A4's bunch of Vw people. Yea I want to get suspension sometime but im worried for when the wife drives it home is all. I have heard that we need adjustable control arms to get the alignment correct again after lowering.
    Sep 15 2013
    MD
    Sounds like a plan. My son has a B7 A4 and probably would like to come as well. Funny is that we have the same color Quartz grey. Obviously we keep it in the family!
    Sent from my mind
    Jan 14 2009
    pasadena md
    Sent from my mind
    Nice, Yea mine is moonlight and I have a son on the way so he will ride in the S4 lol. This is my 3rd S4. My friends have had A4's. Im tempted to buy an A4 avant as a beater and get rid of my civic
    Sep 15 2013
    MD
    Sweet. This is my DD. My 99 GLX passed away with close to 500k on the odometer. Drive train was strong but not the body. This is my 1st Audi including my son. We're pleased
    Sent from my mind
    Jan 14 2009
    pasadena md
    Nice, Yea I have enjoyed all 3 of mine. Don't really have anything bad to say. But I would like to have an audi or vw as a beater but when that deal for the Honda came up I couldn't pass it up. Ive had it for 4 years now and it owes me nothing anymore.
