Results 1 to 10 of 10
    May 25 2011
    Norway
    S-line springs with upgraded shocks
    It's about time to change my shocks and I was searching to see if anyone has tried to run stock S-line springs (1BV) with Bilstein shocks. Anyone try it?
    Thinking of doing a Bilstein B12 kit, but found the ride height would be the same (stock - 30mm) while the dampers would probably be a good upgrade. The added benefit is that OEM springs are cheap and would not need to be approved or registered with the vehicle - which at least in my country is somewhat of a benefit.
    So - anyone run S-line springs and Bilstein or some other performance shocks?
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    Quote Originally Posted by kvitrafn View Post
    It's about time to change my shocks and I was searching to see if anyone has tried to run stock S-line springs with Bilstein shocks. Anyone try it?
    The ride would not be the same. It's a lot lower.
    Pedal Responce first responder.
    May 25 2011
    Norway
    4ringnut, why would an s-line (1BV) spring on a Bilstein damper be lower than the B12 (30-40mm according to source)? Does the shock have a different perch height?
    Apr 04 2015
    Woburn, Ma
    I meant the b12 would be lower than the s line spring.
    - - - Updated - - -
    Sorry for the confusion. I have the b12 kit. It's way lower than they claim.
    May 25 2011
    Norway
    Quote Originally Posted by 4ringnut View Post
    - - - Updated - - -
    No worries :) I had the same experience, but it turned you there is actually two versions of B12 - the prokit (eibach 30mm) and sportline (H&R 50mm). My B7 was really low but rode well, so I think matching the shock with a friendlier spring would be great.
    Apr 04 2015
    Woburn, Ma
    I have the pro kit
    May 25 2011
    Norway
    Really? Ok, thanks for the heads up on that!
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    The S-line/Sport suspension is 20mm lower than the standard setup, which is .75 inches. The Eibach springs are a 1.4 inches and those Bilstein shocks match the Eibach height. I ran Eibach springs (with the stock shocks) on my B8 and I have the sport suspension currently; the Eibachs had a much stiffer ride and the height was functional for daily use but not as easy as the sport suspension when it came to speed bumps and parking lot entrances. I did like the look of the Eibachs; aesthetically the height was great. Pictures of both setups, with 18 inch wheels and 245/40 tires, are below:
    Eibach:
    Stock Sport suspension:
    Sent from the Pedal Responce Emergency Bat Phone
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Jul 10 2007
    Medfield, MA
    Quote Originally Posted by Project Quattro View Post
    That's true in the US, but not in Europe. According to the OP's info box he(she?) is in Norway. In Europe as I understand it, the Sport and S-Line suspensions are not the same. The Sport suspension has a 20 mm drop (same as in the US) but the S-Line suspension has a 30 mm drop (1.2") which is much closer to aftermarket lowering springs like Eibach and H&R OE Sports.
    2016 A4 Premium 6MT | Misano Red/Black | Convenience Plus
    Mar 24 2014
    Quote Originally Posted by kkemp View Post
    Interesting. I didn't know that but I do know the US regs regarding ride height are more conservative than Europe so that makes sense. That would put S-line roughly equal to S4 height, which also makes sense.
