6spd swap, taking up room.
01e trans, rear diff, linkage, shifter box, clutch w/ pressure plate, flywheel, adapter plate, pedals, clutch line, slave cylinder, new master cylinder, front and rear axles (note: one front has bad inner joint), driveshaft, gearshift boot, B5 steering wheel no airbag, came from wrecked B5 S4 which had only 83k miles. Will also fit C5 A6 and Allroad with different front axles. I no longer need this since I bought a manual allroad, it's just taking up space. Local pick up, or can deliver within 200 miles of 17601 if prepaid.
List Date: 1/17/2016
For more info, click here to view the original listing: 6spd swap, taking up room.
This item is no longer available.
